There is no manual adjustment on the TV, nor any obvious way to access the screen parameter change menu, no contrast, colour or brightness adjustment available via the remote. How do I adjust the brightness?
Try this link to download the user manual. Conia and Daewoo uses similar kits to TVs. http://www.manualslib.com/manual/35566/Daewoo-Dlp-2612.html
Gopakumar Gopalan Google
SOURCE: unlock Olevia remote control
Why are the menu settings that I changed not being saved?
A.
The TV is in Showroom mode. The following steps will help you switch to Home mode.
***Showroom mode is designed for retailers to display the TV and to protect from shoppers changing the settings that are predetermined for shelf display environment.***
SOURCE: Digital Signal on my Conia TV has gone. Cant access menu for DTV
I would guess that you are using either cable or satellite for reception. If that is the case, the signal is already a "digital" one. The digital reception you are attempting to receive is the over-air broadcast signal that was implemented recently. This change-over only effected those using external antenna connections. Cable and satelite systems have not changed.
Hope this helps,
Dan
replace with new batteries and it works --- so simple
SOURCE: Sharp AQUOS 65" LCD, No Picture Menu Access
change picture mode from (STANDARD)or other modes and put tv in CUSTOM then you will be able to change the contrast
make sure all cables are in
SOURCE: cannot adjust the color, brightness, contrast etc, using my olevia remote
how to set TV from High Def to Standard Def TV .. olevia
