You can't!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Among other things besides having to reprogram modulation, you'd also need to re-jet it and that's not possible in the field. NG and LPG jets are not the same due to vastly different operating pressures.
Some brands can be field converted but not Paloma/Rheem/Richmond/Rudd Tankless units!
SOURCE: Tankless Paloma NG hot water heater shuts down
have you checked the error codes on the heater?
you can do this by powering off the controler and pressing the up and down keys for a few seconds. this should take you into the diagnostics mode scroll using the up and down keys till you find the one that has the letter E on it and that will give you the last 8 error codes write them down and get back to me
SOURCE: can i convert a whirlpool water heater from
I would recommend to contact the manufacturer. There are certain model of water heaters that cannot be converted at all. The technical support line can answer your question on this. Please have your model, product, and serial number when calling 1-877-817-6750.
SOURCE: Can a Paloma Tankless water heater run on NG?
Yes you can buy a chaneover kit mainly you have to change the jets best of luck
SOURCE: Paloma tankless, gas, water heater, error code C7 76
If you look on the left hand side of the burner control module you'll see 4 capacitors - the capacitors have most likely failed...pretty sure anything code 76 is P/S failure. It may also be covered for manufactures defects. If the cap is blown..the top will be slightly raised as apposed to flat like the other nearby caps - they are called top blow capacitors...the damage should be evident.
SOURCE: Problem for Rheem Paloma PTG-74PVN / RTG-74PVN
hi pete here ill try and help this could be 2 things check the sensor on the unit the outher one is a qustion has the gas company changed your meter latley and turned off you gas and not come back to light your poilet because this code also means not enough gas or wrong type of gas
