I also Faced this problem..its the defect that this phone has got..
so u must try reseting its factory setting..might help this out.
It will Hard-reset your phone as the brand new.So everything will be deleted.
Just backup all your data n reset your phone in factory setting.
Or just dial *#7780# and enter you phone code if it ask;
if you don't know your phones code then see its manual. Or try 12345 or 0000.
Testimonial: "All rite thanks alot"
SOURCE: Nokia C5 bluetooth disconnects automatically,
sir,
you have to change the default memory from phone to memory card. for this go to menu-
messaging-
options-
settings-
other-
memory in use-
and change it from phone to memory card.
SOURCE: How do i get smiley
Your current firmware version is 032.010. And it doesn't supports Smileys in texting. But Nokia has recently upgraded C5 firmware from 032.010 to 061.005. This
firmware will solve the issue. They've enabled Smileys aka Emoticons in Messaging this time.
For updating to this latest firmware ..
Go to Menu>settings>SW Update.
You
must have a NET package enabled since it downloads some files from
Nokia Server. Also make sure that you've enough battery power since it
takes some time.
Hope it helps
SOURCE: I bought Samsung c6112 sliding
samsung gt-c6112 sports to mp4 vids. check ur vids detail properly if problem not solvs then convert video in 3gp video using 3gp video converter.
regards,
shiv c. shekhar
SOURCE: M USING SAMSUNG GT-B3410. M NOT ABLE TO SEE FULL
MP$ is supported but you need the quality of the video to be reduced so that the mobile can view it
SOURCE: How do i play a
Nokia C5 only supports 3GPP, MPEG-4 or H.264/AVC formats. You can convert the avi video to this supported format using any of the free video converters.
Hope this helps, please rate if the solution was helpful, thanks!
