Cell Phones Logo
A
Anonymous Posted on May 18, 2014
Razor valid address required to send this message
Syd Bell
Level 2:
New Friend:
  • Expert 115 Answers
  • Posted on Dec 13, 2014
Syd Bell
Expert
Level 2:
New Friend:
Answers
115
Questions
Helped
28133
Points
279
You have the e-mail address wrong.Might be
a dot instead of a dash you have put in,or missed dot
out.
LUCK
2 Related Answers
Anonymous
  • 85 Answers
  • Posted on Nov 14, 2008
SOURCE: sending sms to email address
go to your contacts go to new entry select that and you have the option there to enter email add.
nige393
  • 39 Answers
  • Posted on Apr 30, 2010
SOURCE: iphone email - sender address invalid
You need to set the outgoing mail server to one you can send from your iphone, ie the one your network carrier lists as you cannot send email through an AOL server unless you are using an AOL connection
How do I validate my Email address?
normally a web site will send you a validation email to a valid email address that you supplied. You need to go to the email and find the message sent to you , check also in spam or junk folders and then open the email and look for a hyper link to click on that will open the particular web site and register you have received the email message .
5helpful
Cannot send email from Yahoo
Log in to your Yahoo! Mail account at http://mail.yahoo.com with your User ID and password.
On the page that opens, find the "NEW" button in the upper-left corner, beside CHECK MAIL. Click it and send email to any valid email address.
  • Type in the email address for whom you are writing to in the "To:" field.
  • In the "Subject" field, enter the subject of your message.
  • Use the large text box to type your message.
  • Click "Send" to send your message.
Presto your message has been sent after you click SEND!
Please don't forget to rate my answer. Thank you.
Mar 09, 2011 • Yahoo Mail
Getting error message when sending messages
Make sure you are connected to the internet, and ensure the email you are sending messages to is a valid address.
What is the valid email format?
ok the valid email format is
[email protected]
username is usually the contact name / handle for the person you are addressing the mail to.
host is the company's server that will revieve and process the mail
.whatever is the extension url
for example.
[email protected]
kevinnobody is the person I wanna send the message to, he can be found @someserver and the ending url is .com
Hope that explains it.
No phone numbers dont have email addresses, A phoe number is similar to that of an ip address which can be seen to be similar to the comcept of a street address..
for example every computer on the internet has a unique ip address,
every line has a different phone number
every house has a different address,
This is what allows computer to interact withone another, or send info to one another. Just as your phone number allows you to call one another and your house address allows you to send mail to one another.
Your email address is similar to that of a mail box. Think of your email address as a virtual mail box, people can send virtual mail to you and you can send to them from it via the internet.
When you get an internet connection your isp assigns you email address (usually) if not you can get free ones from www.yahoo.com and www.msn.com
I am unable to logon to skype(am suspecting a hacked account) and also unable to retrieve/request for a new password as none of my e-mails IDs are being accepted as valid. Now, the support page advises...
If that is the case you need to reopen another skype address and to also inform all ur friends using the old skype address to stop sending mails to u thru it. then send them new skype address in other to embarass ur friends
Aug 16, 2009 • Skype IM
Validation code using single loop for multiple fields in javascript
As example, use it:
JavaScript Form ValidationJavaScript can be used to validate input data in HTML forms before sending off the content to a server.
Form data that typically are checked by a JavaScript could be:
  • has the user left required fields empty?
  • has the user entered a valid e-mail address?
  • has the user entered a valid date?
  • has the user entered text in a numeric field?
Required FieldsThe function below checks if a required field has been left empty. If the required field is blank, an alert box alerts a message and the function returns false. If a value is entered, the function returns true (means that data is OK):
function validate_required(field,alerttxt)
with (field)
if (value==null||value=="")
alert(alerttxt);return false;
else
return true;
}The entire script, with the HTML form could look something like this:
<html>
<head>
<script type="text/javascript">
with (field)
{alert(alerttxt);return false;}
else {return true}
}function validate_form(thisform)
with (thisform)
if (validate_required(email,"Email must be filled out!")==false)
{email.focus();return false;}
</script>
</head><body>
<form action="submitpage.htm"
onsubmit="return validate_form(this)"
method="post">
Email: <input type="text" name="email" size="30">
<input type="submit" value="Submit">
</form>
</body></html>
E-mail ValidationThe function below checks if the content has the general syntax of an email.
This means that the input data must contain at least an @ sign and a dot (.). Also, the @ must not be the first character of the email address, and the last dot must at least be one character after the @ sign:
function validate_email(field,alerttxt)
with (field)
apos=value.indexOf("@");
dotpos=value.lastIndexOf(".");
if (apos<1||dotpos-apos<2)
else {return true;}
<html>
<head>
with (field)
else {return true;}
with (thisform)
if (validate_email(email,"Not a valid e-mail address!")==false)
</script>
</head><body>
onsubmit="return validate_form(this);"
method="post">
</form>
P.S.: If this information was helpful, please rate this solution.
</body></html>
2answers
I cant send emails
If you have yahoo mail forwarding see: How do I verify my email address?
If you are getting error 533 , then see How to verify email addresses
If you use Outlook or Outlook express see:Why am I receiving an error when I send mail from Outlook
If instead ID/Password is not accepted read the following.
  1. Ensure that User ID and password are correct.
  2. Check if you have caps on, the password is case sensitive.
  3. Try using a different computer or a different browser (eg. downloadOpera Browser).
  4. Use Yahoo Password Recovery
  5. See also Yahoo! Password Helper
  6. If nothing worked, open a new account or contact Yahoo!
Jan 17, 2009 • Yahoo Mail
Sending sms to email address
Outbound Text Message
It's a operator message. Your SIM card need to send a message to the operator to inform something about your phone (like you are using a new phone) but the receiver don't recognize for what the message is. Your sim card will keep sending the message until it receives a valid response.
Try to change the SIM card and see what happens. If the problem appears only with one card, you may ask your carrier company to change it.
Top Motorola Cell Phones Experts
Grand Canyon Tech
Grand Canyon Tech
Jose Ramirez
Are you a Motorola Cell Phone Expert? Answer questions, earn points and help others
