The problem you are having is most likely a defective=> WR55X10473 Main Control Board. The defective WR55X10473 Main Control Board may have been caused by a defective=> WR60X10185 Evaporator Fan Motor. If your motor has a white thermistor in the connector you need the related fan motor WR60X10074. If it has a connector for a light you will need a=> WR23X10467 Fan Motor Reason I am telling you this is because if the fan is defective it can again damage the Main Control Board. The same wiring diagram is found=> HERE or HERE by clicking on the wiring diagram. Listen to this video because it explains what I am trying to say. GE Refrigerator Fan Motor Diagnostics If you would like I can walk you through the diagnostic's to see what is going on. I am here should you have questions, Thanks John Tripp Appliance 911
SOURCE: Electrical wiring help for an Evap Fan Assembly P/N 12442204
Heya,
Normally the fan motors are 12v. That means they are not polarity sensitive. You would have to green wires- your earth, then you would have a red and white your active in and active out, as normally these are wired in series. I could be wrong but I have done thousand of 12v evap fan motors and have never has a problem, the clips how ever I cant help with.
Btw make sure the fan motor is not 120v/240v before wiring, if it is get a licensed electrician to do it
Hope this helps any other problems please let me know
SOURCE: GE GSS22WGPH WW won't defrost. Already changed heater.
Replace the thermisters located one at bottom of freezer in back which is the most viewable the other is in the top of the freezer by the fan motor they cost about 15.00 apiece.
SOURCE: Freezer fan noise
Remove the freezer panel to access the fan motor. Look for any obstruction around the fan or blade. Ice, misplaced wire etc.
Check the fan blade. Sometimes they slip down the shaft too far.
If you find none of these issues, replace the fan motor.
SOURCE: have a ge side by side freezer is working fine
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
Water Running in efrigerator from Freezer
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
