Question about Rio Diamond Stealth Graphic Card
My CPU freezes a random times or when i reset it, video will not come on, but the cpu comes on.. I have to power it down a couple of times. Does that sound like a video card going bad? Radeon 7000 graphics card
  • Dick
    Dick May 11, 2010
    Could be any number of problems, including video card, power supply, overheating, or software issue.
  • 20 Answers
It could be your graphics card going, before purchasin a new 1, check that all your fans are working and that your cpu cooling fan or heatsink has not come loose. those type of problems cause the computer to shut down because of overheat. last but not least your hard drive can be going bad and its hitting bad sectors causing it to shut down or freeze.
Posted on Jul 03, 2009
SOURCE:
My tv randomly freezes and and shuts off and them comes right back on and sometimes it squeals when doing that,i was told it was a power supply board,but replaced it and still the same,could the probelm be...
Loud screechy sounds, random turn-off and especially random restart are usually associated with the main board, not the power supply and not the T-CON and not the inverters (when separate).
Of course exceptions are always possible, but the rule is still that the above symptoms point to a bad main board.
Samsung has lots of main boards that develop a symptom of power cycling at startup, freezing image with loud screeching sound and eventually totally dead (although totally dead is also exhibited by main boards from every single manufacturer I know, so no much help there).
Anyway, this is 99.99% chance bad main board, especially considering it is known to develop a problem.
You can find repairs for the main problems of the Sanyo DP42849 and other series here:
http://www.coppelltvrepair.com/search?q=DP42849
Which brings me to the point that it is important to know which chassis version is your model. Some are quite different from others.
Jan 30, 2015 | Sanyo DP42849 42 in. HDTV
I've owned my COMPAQ PRESARIO SR5130NX for several years now, and right out of the box, it had serious issues with freezing. It froze randomly, generally after about 20 minutes to an hour of use, and...
The freezing sounds like it's one of the components are bad. You need to do some testing of components that you can test. You said you increased your RAM to 2GB, Did you buy all new memory or did you add additional to your existing memory? Here's what components I believe could be causing the problem. It's either the memory, cpu, or possibly the hard drive (that is easy to test) Just run a chkdsk from cmd prompt and if it comes clean, then it's not the disk. The last component which is not typically the problem (but can be) is the motherboard itself could have a short. It's not software, or any virus, since you've restored, upgraded, an the like, that usually will wipe any viruses out. I for some reason get the feeling it's the CPU. You said it started from out of the box, and it's been randomly doing this for a couple of years. (your are a very patient person) I would test the CPU HEREs a free cpu tester. If it freezes during the test, then I'd say it's the cpu. If not then you need to start testing each componeant to make sure it's first a compatible part, and 2nd if it's in perfect working order.
Let me know how it goes.
Thanks
Mark
Jun 10, 2010 | HP Compaq Presario SR5130NX PC Desktop
My hp pavilion m7170n keeps shutting off randomly, is this a power supply problem?
You are going to have to test several things when trying to diagnose the problem.
1) It could be *********** Board. Most computer shops will have a test cpu or each particular motherboard cpu style, this allows them to test your CPU and Mother Board.
2) Yes, It could be your power supply. Power supplies do go out randomly, normally a common problem is people forget to upgrade the power supply when they upgrade, say, a video card. Depending on the size of the power consumption of the new hardware the person would need to upgrade the power supply, other wise they end up having the same problem.
3) Have you upgraded your RAM lately? If so then double check to be sure *********** Board can handle it, otherwise it will reset like it is.
Well I hope this helps.
Corey
www.appliancesplus.net
Apr 28, 2010 | HP m7170n PC Desktop
Toshiba Tecra M3 Laptop keeps freezing and shutting down, Can't even do Fresh Install on New Hard Disk Without Freezing, Have Replaced CPU Heatsink Compound.
What made you suspect the compund? You're probably right though. The fan has died or is too slow. The CPU and the video chip are what the fan is protecting. It might require a new CPU chip and fan. If it's the video chip, then a new mother board is in your future.
Good Luck
Mar 21, 2009 | Toshiba Tecra M3 Notebook
My Averatec 3200 turns of randomly...
Check the CPU and Fan/Heatsink assembly. I have a pretty good feeling that the CPU is heating up too much and is not being cooled properly. There may be lint or dust clogged in the fan. You can get access to this pretty easy by removing a few screws on the bottom panel that houses the CPU/fan.
Feb 20, 2009 | Averatec 3200 Notebook
My DC5000 SFF turns on okay then switches off randomly Help!!
Which fan are you referring to? As far as I know the fan in the power supply runs at the same speed at all times. So if that is the fan you are hearing it may indicate that the power supply is failing. The power supply may be over heating and shutting down. I would try a different power supply if you can get your hands on one.
Jan 18, 2009 | Compaq DC5000 PC Desktop
CPU shutting down.
Hi MonaMona,
Replacing a CPU fan is easy, but be carefull, the CPU will have old thermal grease on it, so unlatch the CPU at the same time you take the fan off. Because the CPU will come up with the fan, so unlatch the CPU pins, to release the CPU pins, when taking the fan off. And when putting the new fan on the CPU, & the fan nust be smaller then 80mm, the sell just CPU fans. Make sure you put on thermal grease on the CPU, so it won't over heat & will protect your CPU, also don't cake on the grease. Put on a small amout & spread it on the CPU thin. Let me know if that does it for you.
Good Luck with it.
Mar 09, 2008 | Acer Veriton 5200D PC Desktop
P21G (V3.1) motherboad freezes and wont start
ขอ driver motherboard p 21 g v3.1 หน่อยสิ
Feb 09, 2008 | PC Chips MB PCCHIPS P21G (V3.1) P4M800 775...
Mb doesn't start whith CPU (BOX) cooler clips locked
this is my first attempt at offering a solution so here goes.. what condition do the capacitors look in.. are they bulging slighlty at the top (venting) and is there any brown dis-coloration on them (you can get pictures of faulty ones off the internet)i have just recapped a jetaway board which had 13 out 16 faulty and this fixed the problems i was also thinking that after 2 yrs the cooling compound on the cpu and heatsink may have dried out rs components sell it the order code is 564-311 im sure youve tried all this but thought i'd mention it regards john
Oct 27, 2006 | Gigabyte GA-8IE533 Motherboard
Rio Diamond Stealth Graphic Card Logo
59 people viewed this question
Top Rio Computers & Internet Experts
Alun Cox
Are you a Rio Computer and Internet Expert? Answer questions, earn points and help others
