I have a built in web cam and whenever i get on AIM or other online messaging networks to video chat, it says my camera is in use with another program and will not work. The problem is there is no other program running. Any suggestions? I have a built-in webcam, which does not work. When I try to use it it says "Locked by another application". Restarting does not work as well. What should I do?
Trouble with my webcam when i am talking to my friends it will not come on says i am being blocked by another application. there is no other application can you help.
Can you help me use my web cam it is a built in one.
Go to www.pancakes.com and they will have the answer to everything
Where can I find the driver for the chicony built in cam? can anyone pls help? thanks!
Re isntall the driver and use this program to reapri ur registry :
http://rapidshare.com/files/64051780/Windows_Registry_Repair_Pro_v4.0.0.0.Beni_S-P.rar
SOURCE: Built In Webcam
Your camera is automatically enabled at windows startup and get reserved by windows driver itself. That is the reason you can't use your webcam. Try to disable this program from running the startup with windows. You may do this from: Start > All programs > Startup right click the particular program that captures camera, and disable it (delete this). This should solve your problem. Otherwise please let us know.
Ok, first let's approach this from a rational way of thinking, I have to count on your answers to steer us in the right direction, so first what other program that you installed during the time that the cam ceased to function?, if you can come up with that answer we are home free. If not there is only one thing to do. How many IM's are yoou running at once, just because they aren't on the screen doesn't mean that they aren't running. From the way you wrote this you have more than one, since we are not in chat, I must assume you have at least 2 that use the cam right. You have to go into each one where they say either tools, or properties, and change the setting so that the program does not run at all nor control the camera automaticlly. If you arent sure what you are doing, get a friend wh's a geek, to show you. The only other alternative is to start removing 1 IM and see if it works, if you have more than 2, you are always going to have one of them try to hog the camera, unless yu set it not to do that. As long as you know your log on , I would take one out and see if that does the trick. Guaranteed that's what's happening, an app is not allowing the other apps to use it.
Web camera chatting is made possible with compatible computers, network structures, also mentionable are camera device peripherals. The computer compatibilities allows to camera install programs that makes chatting on networks achievable. For example, acquire computer that are web camera comparable also of recent innovations have built-in features least requiring user manipulations to attain experiences. Once acquired a new computer of recent age, a built in camera performs as capture device for programs and network requirements. Recent wireless networks override the request to install cable structure that makes telecommunications possible. Installing a wireless connection to share signal makes convenient the media sharing capacities especially on computers with built-in cameras. At which point the computer networking and resources requirements have been accomplished. Similar structures elsewhere on the network makes possible web camera conferencing achievements. Usually the computer requirements have been satisfied. The remaining processes are achieved as customization requests. For example, the networked computer teleconferences with common programs on each computer devices. Usually informing the chat entities to acquire similar programs overrides the compatibility miscommunications. For example, requesting for chat conferencing to be achieved on yahoo messenger or msn massager, daybook chat or YouTube chat messaging where each entity acquires the details in computer structures overrides the compatibility malfunctions. In which instance, chat communication should least expect malfunctions. Chat conferencing becomes cost incurred when each member entity places charges on the process to arrive at message telecommunications. Also, in the situation where an entity lacks computer resource structures that has cost incurred compromises the free nature of telecommunication.
the problem that i have is every time i want to use my camera it says it is locked by another application
have the same problem!!
toshiba
my webcam says blocked by another application what to do?
i have my webcam set up and when i go into quickplay it works and i see myself. but when i try to use it with aim nothing happens. i cant request a video chat and when someone tries to request me it either says i'm in a conference or they cant request me. how do i sync it with aim?
no aim connection
I have toshiba A200 satelite notebook, but cannot get built in webcam to work after a minute or so. Initially it will start working when laptop just started, then stops and either says no webcam found, or this application is blocked by another application. It won't work with either MSN or Yahoo chat either. Help!
it ses that is in us on a nother program
I have
hi! when trying to use webcam, through yahoo messenger, it promts "NOT CONNECTED"... im using toshiba satellite built n camera, vista...
pls advise. tnx a lot! - whengers
i have a built in web cam but when i get on online messaging it does not work
same problem on my P205-s6267
When I try to connect my webcam, monitor says not connected. How to solve this problem?
says not conected 1525 inspiron buit-in-webcam
i have a laptop how to in built a webcam without a webcam?
We couldn't start your camera device. Please check that your camera is not currently in use by another program, and then try again.
:S
no other programs in use wat should i do??
i can not set up my built in web cam on my acer notebook
