Procedure 2.3 - Accessing the User Parameter Program
This procedure allows you to change the following settings:
• Set Measurement Units
• Enable/Disable Password
• Set User Name
Procedure
1. Plug the power cord into the wall outlet, then turn on the treadmill with the circuit breaker.
2. Press keys STOP,5,6,7,1 sequentially.
3. The display will momentarily read SELECT UNITS
4. The currently selected measurement unit will then be displayed.
5. Use the UP, DOWN arrow keys to toggle between U.S. STANDARD and METRIC.
6. Press the ENTER key to select the currently displayed measurement unit.
7. The display will momentarily read, PASSWORD
8. Use the UP, DOWN arrow keys to select either PASSWORD ENABLED or PASSWORD DISABLED
9. Press the STOP or ENTER key to exit the program.
Click on "Change your Windows Password" under "User Accounts."
Click "Remove your password."
Type your current password in the field and click the "Remove Password" button.
Click the "Start" button located in the lower-left corner of your screen.
Click "Control Panel" and switch to the "Category" view on the left panel.
Click on "User Accounts" and then "Remove my password."
In Windows XP
hope this helps
If the BIOS password cannot be remembered, the unit will need to be sent in for password removal. This service is not covered under warranty and charges will apply to have the password removed.
Please go to Fix My Acer and set the unit up for service requesting BIOS password removal. In the description please use the following: "Requesting BIOSpassword removal".
Note: This is for the BIOS password only and does not include the Windows login password. Acer does not remove Windows login passwords.
