Have you selected a program? Is water available? You haven't selected delay? Then I suspect it may be a faulty door sensor, it wont start if it thinks the door is not shut. Try opening and reshutting the door.
Start with the basics. Do you have the right detergent and the right amount of detergent? It sounds to me like that could be it. Too many clothes or not enough clothes could do it too. These new washers weigh the load and make an attempt to fix problems by stopping. The motor over amps with suds problems. It has to run more cycles to get the water clear. Yeah the machine checks the water. So if you have too much soap or the wrong soap or the soap in the wrong portion of the dispenser that could be causing it and then their could be a clogged pump filter.
the time is a generic time and will adjust accordingly as goes through programe-for example it allows a certain time to heat in the winter your cold supply may be colder so the machine needs longer to heat water-load size-if its adding more than 30 mins then check filter
That means that the machine detected a problem at a certain point of the cycle and stopped.
If the machine stops when filling check the inlet valve and the water supply.
If it stops because ofervilling check the water level switch.
If it stops when the cycle is hot water only , then check the heating element.
If it stops when draining, then inspect drain filter, drain pump , and drain hose. You access the drain hose removing a panel at the front side of the machine.
If it stops when motor is supposed to spin faster (rinse) then it is motor control unit or motor coupler.
If it is none of the above, then it is a defective control board.
if its no heat there only 2 items it can be heater element or the thermostats u could test the element by replacing the plugged in wires with wires that hasve a plug on place the wires into right places turn the plug on and if the element works it will start to glow turn it off as soon as u see it glowing from the inside of the washer also u can check the thermostats by dropping them into hot water and u should hear them pop
