My 10" digital 2 pad platinum not working its comes on but its not responding no icon or anything I my
Something to try ..
Ensure the picture frame is turned "OFF" by sliding the "power switch" on the left side of the picture frame "down".
Remove the AC power connector from the picture frame.
Remove your SD card that may contain pictures etc.
Re-connect the AC power cord to the picture frame.
Slide the "power switch" on the left side of the picture frame "up", to turn the unit back on.
If the icons still do not appear .. try :
Press "Setup" button on the top-right side of the picture frame.
Select the "Factory Default" menu item.
Turn the picture frame "OFF" by sliding the "power switch" on the left side of the picture frame "down".
Replace your SD card that may contain pictures etc.
If your screen is still blank, the picture frame is faulty.
Hi
try to see if you have a reset hole in the back or sides if not then try to reconect the battary or to empty the battary .
