You may follow the steps mentioned below to restore the Dell XPS M1330 to its factory default:
1 Turn on the computer.
During the boot process, a blue bar with www.dell.com appears at the top of the screen.
2 Immediately upon seeing the blue bar, press <Ctrl><F11>.
If you do not press <Ctrl><F11> in time, let the computer finish starting, and then restart the
computer again.
NOTICE: If you do not want to proceed with PC Restore, click Reboot in the following step.
3 On the next screen that appears, click Restore.
4 On the next screen, click Confirm.
The restore process takes approximately 6-10 minutes to complete.
5 When prompted, click Finish to reboot the computer.
NOTE: Do not manually shut down the computer. Click Finish and let the computer completely reboot.
6 When prompted, click Yes.
The computer restarts. Because the computer is restored to its original operating state, the screens that
appear, such as the End User License Agreement, are the same ones that appeared the first time the
computer was turned on.
7 Click Next.
The System Restore screen appears and the computer restarts.
8 After the computer restarts, click OK.
9 You will need to run Windows Update as well as Live Update for your virus protection as these will be seriously out of date.
Hope this helps..
SOURCE: Dell XPS M1330 PC Notebook can't connect to the external monitor
No. You just basically need a VGA cable. Check your video settings.
SOURCE: Bluetooth is not working on dell laptop Xps m1330
HI
LAST DAY MY LAP HAS GOT THE SMAE PROBLEM . YOU JUST REINSTALL THE BLUETOOTH SOFTWARE FROM THE DRIVER INSTALLATION DVD PROVIDED WITH YOUR LAP----OF COURSE NO DOUGHT THE PROBLEM IS SLOVED.
THAHK YOU
SOURCE: time-of-day clock stopped on dell xps m1330
When you alter the Date and Time and next time you boot up again the date and time has reverted back to some other time, this indicated the BIOS battery is flat and it needs to be replaced.
To fix this problem, replace the BIOS battery and change the date and Time setting.
SOURCE: Dell XPS M1330 battery not detected!
Normally the life time of a laptop battery is 300 cycles. that is 300 discharges and charges. Since your laptop is almost 2 years old, the battery could be at the end of its life time, and again depends on how often you use your laptop in a day. Better goto a service center or get a similar battery from any of your friends just to make sure it is not a motherboard issue. Then you can think about which part you've to replace.
Please come back and rate my solution if it turns to be helpful fro you, or also if you need more clarifications.
Thnx
SOURCE: how do i restore my Dell XPS M1330 back to factory
Try either F8 or F11 keys
or CTRL and F11 together at start up
