Question about Precor EFX 556 Elliptical
Will not shut down
I bought a Precore EFX 556 used. When i purchased it it shutdown or went to sleep. That was one of the most important features i wanted. Now that i have it in my home, i plugged it in and did my workout routine, and now it wont go to sleep. i have to unplug it to turn it off. It was my understanding that you turn it on by pedaling and after a few min of not being used it should shut down. What am i doing wrong
  • Precor Master
  • 1,594 Answers
2 Suggested Answers
SOURCE:
maxtreadmill
  • 832 Answers
SOURCE: efx 556
Lost communication between the upper and lower board You have 2 interconnect wires and mid point connector . You may have a loose connection at any of of the 4 connection point or a bad wires. Go to gymparts.com on left hand side you will see diagnostics and repair click on it scroll down until you Precor 556 look for you serial# and click to PDF and it should give you the necessary info to hunt your problem down
Posted on Apr 09, 2010
New precore 5.33 elliptacal squeaks
bar soap on the ramps where the wheels travel until the shine wears off the wheels. I see it at warranty calls every week
Mar 24, 2014 | Precor Efx-5.33 Elliptical Machine...
Gateway MT6707 shutdown problem
Open the Control Panel, select Power Options, select High Performance, select Change Plan Settings, Under Plugged In, set time to Turn Off Display, set Put the Computer to Sleep to Never, select Change Advanced Power Settings, scroll through the settings , click on the + at Power buttons and Lid, set to shut down, Sleep and Hibernate to Never, adjust the rest to your preference. When you are not using the Laptop ALWAYS shut down and unplug to prevent damage due to power surges.
Apr 03, 2013 | Gateway Computers & Internet
WHY DO MY COMPUTER STARTS WITH TWO STEP?
Sounds like it is in sleep mode at startup. On some compaq, hp, and emachines the power button also serves as a sleep button. If you touch it, they go to sleep, hold it down at least 4 seconds, they shut off. If it was shut off this way that could happen. Also look in display properties under sreenssaver/power options to find the timeout on going to sleep, hibernate, password on waking up, using the tabs,(xp), or categories on the left (vista, 7, 8) to find these features. Also check under power schemes, advanced, and UPS to select timeout features and password on waking up. If it was touched to sleep, touching it should wake it up and allow it to be shutdown properly. On the next startup it should be normal.
Mar 14, 2013 | Computers & Internet
CHARGE BATTERY ON PRECORE EFX546I
The machine recharges the battery while in use. If your battery is dead, chances are you have a battery with some dead cells. You will need to locate your battery, usually mounted under the lower electronic board. You can try a 12 volt charger, or purchase a replacement battery. Precor Equipment Repair Parts Treadmill Belts Ramp Sleeves SPORTSMITH...
Oct 14, 2012 | Precor EFX 546i Elliptical Version 4
Precor efx 556
Here you will find parts and other information for the Precor EFX 556.
Repair Parts for Precor EFX 556 Ellipticals SPORTSMITH net
Jan 07, 2012 | Precor EFX 546i Elliptical Version 4
My new precore has a squeaky noise when i an on it what can i do to get rid of it. can i use wd40 on the wheels?
No please do not. If the wheels are noisy, they need to be replaced. If something else is noisy, it needs to be addressed - spraying things with lube rarely fixes anything, and can cause more damage.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/russell_1d1c35fa8a5a0be4
Aug 09, 2011 | Precor EFX 546i Elliptical Version 4
Satellite A505 laptop running windows 7 64 bit when using shutdown options and selecting sleep mode system does not go to sleep it freezes and must be manually shut down which generates a windows was...
Sleep and hibernate options are part of Bios. what i mean by that is if these is an issue with Bios these features wont work. Sometimes there has been known issues with cordless mice and other devices plugged in via usb port. Also outdated video and other drivers will do same. i would recommend first of all going to manufacturers site and downloading latest Bios update for your system, once this is done run windows update and make sure pc is restarted once done. After all this go back to your manufacturers site and download all of the driver updates that are available. Hope this helps.
Mar 10, 2011 | Toshiba Satellite A505-S6975 Notebook
Efx 556 ERROR EE32 WHAT DOES THIS MEAN?
Jan 12, 2010 | Precor Exercise & Fitness
Sleep vs Shut down
It depends on how long computer is being used in a day.
for general use
you can shutdown your computer once in 2 days but i highly recommend not to put in sleep mode and betting putting in hibernate mode instead of sleep mode.
note: most of simple issues are resolved by restarting PC so you can guess now how important is to shut down computer.
Good luck,
Mar 25, 2009 | Apple 24" iMac Desktop
Hp laptop random shutdown - overheat?
Your CPU is likely overheating. Very likely the thermal conducting material between the CPU chip and the heatsink may have shrunk and now impeades the thermal transfer.
You may need to remove the heatsink and put new thermal paste and perhaps copper shim to restore the thermal contact to the heatsink.
Jan 04, 2009 | Everex StepNote XT5000T Notebook
Precor EFX 556 Elliptical Logo
237 people viewed this question
Top Precor Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
Ross Metcalfe
Ross Metcalfe
Jose Pino
Are you a Precor Exercise and Fitnes Expert? Answer questions, earn points and help others
