SOURCE: no screen on starting laptop
remove the battery from bottom, plug into ac power pack, and try it that way
SOURCE: Black Screen, can hear sound though
I learned recently that, since I purchased mine with a VISA card, VISA automatically doubled my warranty to extend it to a second year. Hope this helps someone else.
SOURCE: "0x71ab6a55" reference memory 0x71ab6a55 couldn't be written, Err
Run a SCANDISK on the hard drive. That is referencing a drive sector, so by running a scandisk it will attempt to solve the errors and block the sector from being used.
Scandisk can be found by right-clicking the C: drive in MY COMPUTER then choosing TOOLS. Checkthe drive for errors. When you ge the YES/NO option box to run it when you reboot tell it YES and then reboot the PC.
SOURCE: HP Pavilion DV7 Display problem
How long have the colors on your display been "reversed/inverted" and looking like a negative....... Did you drop or damage the laptop in any way (sudden shock/bump)? Also, has it been allowed to overheat (if you run the laptop while it is sitting on a soft surface such as a bed, pillow, couch, etc it can allow the motherboard to overheat because it cannot get the airflow through the cooling system through the fan/vents because they are blocked). Have you checked to see if your laptop is included in the "HP Service Enhancement" program???
