Dell HK395 Computer Speakers Logo
Gunther Sutherland Posted on Jun 23, 2009
Transformer blew on Hk395 speaker sysytem
Transformer blew, need replacement but don't know output voltage.
Anyone know what voltage it should be on the output to the board?
  • dimrilldell May 11, 2010
    I think I remember it being in the 12-24VAC range.  I you are still interested I will open mine up and measure it.
dimrilldell
Level 1:
Problem Solver:
  • Contributor 6 Answers
  • Posted on Aug 16, 2009
dimrilldell
Contributor
Level 1:
Problem Solver:
Answers
6
Questions
0
Helped
4846
Points
10
I think I remember it being in the 12-24VAC range. If you are still interested I will open mine up and measure it.
1helpful
1955 Wurlitzer 2400 series jukebox was smoking then quit. There is no visible damage however the fuse blew. Is the transformer bad?
Disconnect the output side of the transformer, fit a new 2Amp slow blow or time delay fuse and plug it in.
If it blows the fuse again or smokes, the transformer is at fault and needs replacing.
If it is fine, fault find the rest of the electronics,
Fuses are available from most electronic hobby stores or outlets, the transformer will require rewinding at a specialist workshop.
Output voltage Mordaunt Short MS308
Most makers specify the transformer as a safety part which can only be replaced with a manufactures specified part. Contact them for the correct part. If you can't get one from them, then replacing it with a none recommended part, could pose a fire risk.
1helpful
What is the output voltage of the transformer in the system, mine is burnt so i need to change the transformer so i need to know the output voltage
Nominal Output Power (Total) -- 2.3 Watt
On the back of the right speaker where the power cable is connected there is a sticker where you can see the voltage the speakers are using. You should read there 120 V - 60 Hz 100mA.
You will have to use a voltage adapter from 120v to 220v. (found in electronic shops) that maintains the Voltage stability.
Regards,
Tariq Khan
2helpful
2answers
I also have an Athena ASP4100 sub woofer which blew the fuse on the circuit board and when I replaced the fuse, it just blew it again. As an electrician, my understanding would be the circuit board has a...
You should look at the circuit board for the power amplifier and check for any leaking or bulged electrolytic capacitors. If this speaker uses the circuit boards made by AMI (such as most JBL and Mission sub woofers around 1999-2001 vintage) they had a lot of problems with this as well as bad modules. Google for the module S53AMI and you will find lots of info if this is what you have in that Athena.
1helpful
Need a driver for hk395 speakers to use with vista 64 bit sysytem
You don't need drivers of any kind for your speakers. You only need drivers for your independant sound card or for the sound card on your motherboard to be able to get sound from your pc through your speakers. Check your sound card setup.
I need the input voltage for ac adapter for my GE 98903 2.1 Pro Speaker System
The AC adapter input voltage is 120 Volts AC as it plugs into a wall outlet. I suspect you want to know the output voltage of the transformer. If you have the old transformer the output voltage is listed on the transformer top. May be hard to read but it is there. This system is also sold under then brand name Jasco. The Input voltage of the system should also be printed next to the power connection or on the speaker itself.
Main amplifier may be blown
if your speakers have a warranty can you return that to the store with the receipt because the store will replace a new for defective product..or you can go to the web site of the brand of your speaker if you intent to buy the main board you can order trough the online shopping.
15helpful
5answers
HK395 Speakers/Subwoofer Cable
Top Dell Audio Players & Recorders Experts
SmartAviator
SmartAviator
ADMIN Andrew
ADMIN Andrew
 Grubhead
Grubhead
Are you a Dell Audio Player and Recorder Expert? Answer questions, earn points and help others
