The Mac is locked and has it say you need a code to open, so if you know the person who gift you the Mac ask for the code if no the only remedy is to re-load the system but you will need the the copy of the O.S.
Hi, You can unlock a Samsung E2600 using unlock code. You can get the unlock code for a Samsung E2600 from www.onlinegsmunlock.com/samsung-e2600/rs7wp9/ at affordable cost. Here are the steps fro unlocking a Samsung E2600, 1 - Switch ON your Samsung E2600 with a NOT ACCEPTED SIM Card.
2 - Samsung E2600 will ask for "Password".
3 - Enter the Unlock Code.
I have lg kc550 given to me as a gift last year, the issue with the phone is that it will load up to the main screen, yet none of the button or function work, how can I reset to factory specs using date cable. Which driver do I need to use in order to correct the problem, IMEI: 353834-02-001993-6 S/N: 806KPWQ001993, this phone is being using in the Mexico, the phone has been unlocked from the original owner
Have you removed the memory card and moved the switch in to the lock position by mistake? if so take out the card and slide it into the unlock position. hope this helps
need unlock code for ur mobile to get unlock, i found a site here unlock can be done i found this last week just turn in to this http://www.unlock-zone.com/
To unlock your set requires two steps: the first is to get past the lock screen.To do that, press the QV( or previous channel?) and 9 buttons at the same time when you are asked to enter your lock code.
Now that you're past the lock screen, find the menu that covers locking and unlocking. QV/9 (previous channel/9) is a one-time bypass; if you turn the set off, it'll be locked again when you turn it on, so you first need to LOCK it again, with a pass code you can remember (try 1,1,1,1). Once you lock it, you can exit from all the menus, then try to change inputs. It'll ask for a pass code, which you now know!
Please ask for further clarifications and rate the solution as Fixya if found useful.
