When my washer starts to spin, it starts to bounce and makes a lot of noise. It seems to work okay during the actual wash Any ideas
SOURCE: hotpoint ultima wt960 washing machine noisy on spin
Bearings faulty or another fault this model suffers from is the concrete balance weight retaining bolts shake loose, if it is the bolts tighten up as soo as possible. Regards Advisor
SOURCE: Hotpoint VBSR2080WOWW washing machine vibrates with loud noise
hi,
this is a generic problem with top-loading washing machines. when the distribution of load is not uniform, it gives sound when spinning. if it produces noise even after equal distribution of clothes, the problem lies in the suspension. this is not a major fault, and can be put up with, rather than spending dollars on fixing it. this will in no way cause any special wear and tear for the machine.
cheers
SOURCE: I have the hotpoint wma40 washing machine and it
its possable the pump or drain hose is blocked.Could also be the pcb (main control board
