Call Hp Technical Support for the Assistance. Support For Hp Printer Call Toll Free 877 690 9305
SOURCE: HOW to print ONLY in Black and White when the original is in color
If printing from computer windows base
The all-in-one will reproduce many colors
exactly; however, it is normal that some colors may be slightly
different in shade or hue. If the colors are more than slightly off
though, there is a problem.
Review the information below to correct the problem:
If printing from Mac
** and chances if you are printng from computer might not have an option to print draft B and W, just check for quality.
Hope this helps, if it does pls dnt 4get to rate solution, thanks!!
SOURCE: My HP officejet 4300 series stopped printing and
To get back online of your printer, go to Control Panel and Select Printer & Faxes then OPEN.
A list of Printer is on the browser, point the printer with your mouse then right click on your Printer HP OfficeJet to select Printer Offline and click it to go back Printer Online. Good luck!
SOURCE: HP OfficeJet 6110 Prints very slow then aborts about 1/3rd way through print
I identified this issue with my Officejet 6110xi All-in-One as firmware corruption. Attempting to install the supplied firmware update gave the error that "no hp device connected to the computer would benefit from it at this time." Attempted to power down the printer using #9 keystroke and got "FULL RESET" message, but problem of extremely slow printing and erratic behavior of the print heads persisted. I solved the problem by putting the printer outside in cold weather for two (2) days. This frequently resets firmwares with software corruption back to their embedded EEPROM state. Hooked the printer back up and worked fine. If cold weather is not available you could try other creative methods of cooling the device, just use a plastic bag and with ideally some drying packets thrown in to prevent excessive moisture buildup in the cold environment. The colder it is the faster the firmware resets.
-Paul Ronco, Computer Technician
www.paulronco.com
SOURCE: how to check if the ink is ran out from hp
If you have full installed HP program that came with Printer then you can find Ink Level using HPTool Box utility.
another way is find out is that if your prints are comming light then its time to refill or buy new toner.
Third way is to judge by Toner weight. if low weight means also there is low ink.
Give a callto HP Support (877-690-9305)
