I changed the fuel lines and replaced the primer bulb, but I cant remember witch way the fuel lines go from the tank to the bulb and from the bulb to the tank. Your help would be greatly appreciated. Thank...
The longest, and sometimes smaller in diameter of the two Fuel Lines, goes from the bottom of the carburetor, to the bottom of the tank. (The first line will need to be longer so that you can pull it all the way through to where you put gas in.) This so that you can easily attach the fuel filter. Then pull the Fuel Line back through the hole. Leave enough slack in this line so that the filter that attaches to the end will rest comfortably at the bottom of the tank. Cut off any excess line once you know that you have enough to reach the carburetor.
The other Fuel Line goes from the primer bulb to just inside the tank,(about a 1/2 inch). (Make sure that you get the right size fuel lines.) The plastic coupling goes on the end of this line, inside the tank. This keeps the line from pulling out of the tank.
(HINT): When feeding the Fuel Lines through the fuel tank holes, cut the lines at an angle. They will feed much easier into the holes. You can than cut them off square, once you know that you have enough to work with.
Three Fuel Line Installation: In this installation, the primer bulb is separate from the Carburetor.
The (1st) Fuel Line will be the longest, and sometimes smaller in diameter of the (3) Fuel Lines. It goes from the bottom of the carburetor, to the bottom of the tank. (The first line will need to be longer so that you can pull it all the way through to where you put gas in.) This so that you can easily attach the fuel filter. Then pull the Fuel Line back through the hole. Leave enough slack in this line so that the filter that attaches to the end will rest comfortably at the bottom of the tank. Cut off any excess line once you know that you have enough to reach the carburetor.
The (2nd) Fuel Line goes from the top stem of the primer bulb to just inside the tank,(about a 1/2 inch). (Make sure that you get the right size fuel lines.) The plastic coupling goes on the end of this line, inside the tank. This keeps the line from pulling out of the tank. This will be the shortest of the three Fuel Lines.
The (3rd) Fuel Line goes from the bottom stem of the primer bulb to the top of carburetor
