My son just bought a new 120gig harddrive for the ps3 and everything was fine., now 1 month later after watching spider man 3 on blue ray there is no power to the console can you help?
BUT A NEW POWER SUPPLY OFF OF EBAY !!!!!! IT WILL COST YOU AT MOST 47.98 DO NOT PAY MORE THEN THAT .......!! TRUST ME DO NOT PAY SONY NOTHING 150 DOLLARS IS OUTRAGEOUS WHEN I KNOW FOR A FACT ALL THEY DO IS SWITCH OUT THE POWER SUPPLY UNIT ..THAT IS ALL THEY DO .....!!!!.....I HAD THE SAME PROBLEM ......I WAS PLAYING COD WORLD AT WAR AND THEN OUT OF NOWHERE IT JUST SHUT DOWN COMPLETELY ,..WHEN I TRIED TO TURN IT ON IT SHOWED A GREEN LIGHT FOLLOWED BY AN AMBER LIGHT QUICKLY TURNING TO A FLASHING RED ........I THOUGHT IT WAS AN OVERHEATING ISSUE BUT MY AMBER LIGHT SHOWING INDICATED A HARDWARE ISSUE SO I TOOK A CHANCE AND BOUGHT A POWER SUPPLY UNIT OFF OF EBAY AND RECEIVED IT WITHIN A WEEK .......IT BOOTED UP PERFECTLY FINE TRUST ME ...FOR GET SONY AND TRYING TO DO ALL THAT FANCY TRANSISTOR SWAPPING GEEK TALK BULL......JUST SWAP YOUR POWER SUPPLY UNIT AND THATS IT ...YOUR PS3 IS BACK ONLINE !!!!!!!!!!.....THATS IT BOTTOM LINE !!!!!!.....TAKE MY ADVICE OR LEAVE IT I DON'T CARE BUT I FIGURED I SHARE THIS WITH YOU GUYS SINCE I WENT CRAZY RESEARCHING WHY THIS HAPPENED AND I BASICALLY PUT COMMON SENSE INTO THE EQUATION TOOK A CHANCE AND BAMMMM!!!!! BABY I FIXED IT LOL..LOL...HOW ABOUT THAT ..FOR ALL YOU SO CALLED KNOW IT ALL PEOPLE OUT THER ..LOL..LOL.!!!!!...DAMN GEEKS TURNING THINGS INTO ROCKET SCIENCE ALL THE TIME .....LOL...........EBAY OR ANY OTHER PLACE YOU CAN GET YOUR HANDS ON ONE OK .........THANK ME LATER OK ..LOL.....TAKE CARE ..
My PS3 had no power (no red light). I deceided to buy a power supply on Ebay (cost me 40$ CAD with shipping) and change the part myself using a guide on how to dissassemble the PS3. I took my time and everything went fine. My PS3 now work like before and it took me 1 hour to do.
Http://www.edepot.com/playstation3.html#PS3_Power_Supply
In the above link, you can order the correct Power Supply for your PS3 model. It also lists all the different power supply model numbers available. You can now replace your power supply to get a quiet PS3! Less wattage means less heat from the Cell and RSX. Which means the fan is not always at highest level!
Check the PWM circuit in the unit those along with drive transistors often fail in these supplies due to its compact size (they often cheap out with parts) also check duty cycle when it works.
It seems that the first gen of power supplies are burning out. I have seen over 150 units with that problem. Unfortunatly it is very hard to get a new PS for the PS3. You have a few options, call Sony and ask how much it would be to fix it, sell it as-is on eBay (could get you about $150-230), or pray it's still under warranty. Good luck.
A ton of the earlier PS3 power supplies are burning out, don't even bother fiddling with it because it may just wind up damaging something else. You can just replace it and get the PS3 power supply here with a warranty here PS3 Power Supply
Yes, the PS3 power supply and PS3 lasers seem very unreliable. Sony charges over $150 to fix. There are many tutorials to do it yourself, or you could even send it to us for repair. We retail both parts online.
Checkout our site OverstockDistributing.com for a good deal.
My friends told me that PS3'S are auto voltage is it true? The unit says
120 volts.
Allrite people all u gota do is replace the power supply and you can buy it on ebay
I have got PS3 from the USA, and as known the power input is 110 volt, .....what I asking , if it could be run on 220 volt input.
Regards
K. saman
Thanks For Helping Me This Was My Commet and I Already Sent In For A Brand New Playstation 3 Console And They Waved The Proof Of Purchuse And Are Just Sending Me A New Console............. Thank God..............
PSN ID: DarkWater2007
Same problem here. I bought mine "As Is" from ebay, cracked it open and discovered that it is in fact the power supply that is the problem, not sure which part though. There's a Fuse that I found to be blown, replaced it, powered it back up, and it blew again. Input seems fine up to and beyond bridge rectifier, but after that, it's a bit too complicated for me to troubleshoot. Anyone have any idea which part it is? I suspect one of the many larger transistors, but I haven't got it narrowed down yet.
Has anyone actually fixed one of these power supplies before? Or is everyone just buying new PS3's instead? Any insight would be most appreciated.
Thanks,
-Chris
Yeah i have the same problem but no blown fuses. I checked the bridge rectifier as well as the thermal resistor but beyond that I have no clue.
i'm having overheating issues with my ps3 (no warranty). even if i rig the fan to go at 100% speed it shuts down and beeps. where can i find the "THERMAL RESISTOR"??, i think it might give the wrong temp value.
I had the same problem, I was playing COD4 one day, when suddenly the console shut down, thinking it might've just been the power at home I tried turning it back on but it wouldn't turn on again, no lights, no sounds nothing. I haven't taken a look at the psu yet in detail but I think it most likely is the same issue
red light flashing.Checked Inside Console,Definetly a power fault,Cant See anything burnt out though,
The D10XB69H solved the problem of my burning fuse, But still doesn't work!
11.28.08 - Less then a year old and no power? It is not the cord, I tried it on my TV and i works fine. Help?
the same problem, PS40 GB US ... Power supply looks good, no burned areas, fuses ok... i will try to mount good PS from my colegue system.
Im in australia and typed in ps3 power supply and stuff all came up. any search ideas? im keen on finding a solution and this describes my situation to a tee.
My husband bought a playstation 3 console and it overheats and blinks on and off. What do i do about the situation get back to me as soon as possible.
check out 5 volts ,if no 5 volt suppy will not turn on
