1993-1997 MAZDA MX6 PRIMERED HOOD STEEL PANEL ASSEMBLY 2DR 1994 Logo
M
Matt yancer Posted on May 16, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Why wont my 1994 Mazda mx6 ls wont start up, wont spark, just turns over, WHY?
So here's whats up, I was driving and hear a strange sound, it wasn't loud just a faint sound not sure what it was. Then I tried to give it gas and rps dropped in the low hundreds. I pulled over and it was running rough, could barely get it into first gear without it essentially seeming to die anytime I gave it gas. I cut it off and did a quick roadside check, which no conclusion. I attempted to restart the car, and after a few rough attempts it started and I crawled back home in first without pressing the gas pedal. The next day, the car wont start. I checked for fire to the sparkplugs, and no sparks. The car will try to start but just isn't getting spark. I did the wire trick to get the "codes" from the flashing engine light by doing this: [URL=http://s299.photobucket.com/user/spyfox44/media/20140515_173850_zps8a40a1bf.jpg.html][IMG]http://i299.photobucket.com/albums/mm313/spyfox44/20140515_173850_zps8a40a1bf.jpg[/IMG][/URL] Then I video recorded the engine light flashing "code" and it flashes 8 times and some after that, which I don't know what that means: [url=http://youtu.be/hRwsyuxVF3E]1994 Mazda mx6 wont spark/start codes - YouTube[/url] I think it may be the Ignition control module, but I guess that's depending on this code. Thanks for the help, Matt
Marvin Chisom
Level 2:
Champion:
  • Expert 218 Answers
  • Posted on May 16, 2014
Marvin Chisom
Expert
Level 2:
Champion:
Answers
218
Questions
Helped
48378
Points
491
Before trying to start any further, you need to remove the timing belt cover and make sure the timing belt hasn't jumped or broken. That's the first place I'd look. Hope this helps
2answers
96 mazda mx6 buzzing sound when tryng to start will not turn over has new starter and battery
No Crank, No Start Diagnosis - EricTheCarGuy - YouTube
? 12:22
https://www.youtube.com/watch?v=BrqkhZmDnHQ
Feb 26, 2012 - Uploaded by EricTheCarGuy
Visit me at http://www.ericthecarguy.com/ Whenever you have ano start condition when attempting to start your ...Missing: mx6
Why My Car Won't Start? - Reasons and Solutions
www.myautorepairadvice.com/car-wont-start.html
Before I even put the key into the ignition I hear a clicking noise on the right side ...Everything is turning over, but my car won't start. ... I just replaced the starter, battery, and alternator on my 1994 Nissan Sentra. ... (1998 Mazda Millenia 2.5L) ... This is the second time this has happened, and both times I started the jeep to ...Missing: mx6
How To Diagnose A No-Start ' DSMtuners
www.dsmtuners.com > ... > Articles: Miscellaneous
Mar 4, 2006 - 2 posts - ‎2 authors
Diagnosing a No-Start I've been seeing a lot of No-Start related ... II - The car cranks, but just won't start. ... Stock fuel pumps will emit a faint buzzing or whining noisewhen they ... You'll hear the clicking each time the injector fires. .... You'll want to check that spark is getting to the engine as its turning over.Missing: mazda ‎mx6
Hard Starting, Any Advice? - Mazda626.net
Remove ac expansion valve on mazda mx6 1995 ls
A/c system must be emptied and reclaimed. takes a recycling/charging station to perform this. you must seek a repair shop licensed for refrigerant handling to comply with federal law. discharging refrigerant is done by specially trained and equipped persons. then its a simple thing for them to do for you
1helpful
I have a 93 Mazda mx6 Ls... Everytime I step hard
When my MX6 was doing this it turned out to be an hydraulic leak from the clutch master cylinder, which runs on the same fluid reservoir as the brakes. Clutch master cylinder replaced and all good again!
2answers
If 1993 mazda mx6 does not start and there is no electricity inside of car what is wrong?
hi this sounds like the battery is flat, get it checked out it might need replacing hope this helps
2answers
1997 mazda mx6 v6engine the front axle onthe
They are supposed to come out. Any chance of removing the other Axle and seeing if the axle can come out by driving it out with a punch and hammer?
94 mazda mx6 wont start,getting fuel, got spark, what could it be?
First check your air flow to your intake. To have combustion you gotta have fuel, spark, and air. Also check your MAF (Mass Air Flow Sensor) This is located just before the intake. If its not this, your engine timing may be off.
Car wont start
being 94' im sure it has high miles, cam and crank sensor common to fail over time do to wear and heat exposure. check the basic, make sure you getting fuel and sparks. fuel pump only work as long the engine is turning over due to the crank sensor sense the flywheel turning. crank sensor may be faulty. no sparks, check coil make sure is good and putting out 12v, auto zone can test it for free. good coil, than check cam sensor, cam sensor senses the cam turning and tell the ecu to tell the coil to disperse the sparks to the plugs. cam and crank sensors, there no way of testing it but replacing the unit unless you have the special equipment to test it; both is fairly cheap to replace, check ebay.
3answers
1994 mazda mx6 problems
It has a transmission problem. take it in for a scan. That should reveal the possible causes too.
Rate this
Help 94 mazda mx6 v6. wont start, got spark , getin gas, in time, need help please.
search for MX6 HEI conversion, should solve your problem for $50.
Ed
1helpful
Mazda mx6
did you try replacing the ignition module?
every time that happened to me, it was exactly that. I have found an inexpensive way of repairing this.
Top CARPARTSDEPOT Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
john h
Are you a CARPARTSDEPOT Vehicle Part and Accessory Expert? Answer questions, earn points and help others
