Vacuums Logo
A
Anonymous Posted on May 15, 2014
Where is riccar radiance filter reset button - Riccar Vacuums
Thatvacguy.com
Level 3:
  • Riccar Master 1,619 Answers
  • Posted on Aug 11, 2014
Thatvacguy.com
Riccar Master
Level 3:
Answers
1619
Questions
0
Helped
604948
Points
3345
Remove the bag door, you will see a little round rubber piece about 1/4 in diameter on the motor cover. Remove the rubber piece and very gently push the button while the brush roll motor is running
2 Related Answers
Anonymous
  • 17 Answers
  • Posted on Oct 02, 2008
SOURCE: riccar 1500p vacuum won't start
it has a thermal fuse that shuts it down if it over heats. Check the hose , wands and floor tool for blockage and check your bag and filters as well.
Anonymous
  • 52 Answers
  • Posted on May 21, 2010
SOURCE: riccar model rad.7 upright (radiance). roller
As you already know, the red brush indicator light indicates that the brush roll has stopped turning, usually because an object has become stuck in the brush roll. When that happens you should turn the machine off (unplug it also for safety), remove the obstruction and turn the vac back on. That should have cleared the light and allowed your brush to turn again.
Occasionally, you will get debris in the brush roll end caps and the brush roll will spin slower making the sensor think there is an obstruction. You can remove the brush roll, pop the end caps off and clean out any debris to see if that helps.
If none of the above worked it is possible that the brush roll sensor is bad or the circuit board in the machine is bad. You'll need a Riccar service center for that. The good news is your Radiance has a 6 year warranty.
Where is the reset button on riccar supraquick
Link below to company with some info and contact info
https://www.riccar.com/customer-support
One place it says if your vacuum has a thermal overload reset see owners manual if vacuum will not start. It also says make sure hose is not plugged and filter and bag are good.
Manual below has a troubleshooting guide
http://media.riccar.com/manuals/RSQ1_OM1706.pdf
https://az589519.vo.msecnd.net/productdocuments/Riccar_RSQ1_supraquick.pdf
My belt came off my Riccar Radiance when I took the brush out to clean the hair off, how do I get the belt back on
The belt has to go around the motor shaft then under the roller on the pivoting lever (it's called the hall sensor) then around the brush roll. It may be easier to remove the top cover of the nozzle housing by removing the 5 screws from the bottom of the vacuum.
How can I determine the age of my riccar radiance upright
Your dealer may have written the purchase date on the tag for your maintenance plan. If not your dealer can determine the age by using your serial number
Is there a reset button
The reset button is internal. If it overheats it will shut off but will come back on when it cools down. This usually means you have a clog somewhere or a clogged bag or filter. If that doesn't take care of it have it checked by your Riccar dealer.
1helpful
Accessing the motor on a riccar radiance
On a Radiance you will need to remove the screws going through the bottom of the vacuum nozzle housing which hold the cover on. Remove the cover and remove the screws holding the cover that goes from the brush roll to the lower motor. When you remove this cover tpyou will be able to see into the fan of the lower direct air motor to remove the obstruction. If it is in too far. You may have to pull the motorand open up the fan. This is not a hard thing to do but. If you have never done it, it can be a confusing job that may be best left to your Riccar dealer.
Broken handle riccar radiance
Take the broken part to your Riccar dealer. The newer models have an upgraded more durable handle. You can get the upgrade for an older model.
4helpful
Stopped running. Filter was clogged. Cleaned filter and changed bag, but still won't start. Motor was warm when it stopped.
Hi There,
This sounds like the Thermal Switch in your motor tripped. All Riccar vacuum cleaners have a motor reset switch, that will shut the motor down when it gets hot. Usually it's caused by a full bag, clog, or dirty filter.
Try resetting the thermal switch first. If this doesn't work, you may have done some more serious damage to the motor, and it might be a good idea to take it into a local Riccar dealer in your area.
Here's a step by step guide on how to check the reset switch on your Riccar 8850:
To reset the thermal fuse:
  1. Unplug the vacuum cleaner
  2. Check for problem – over–filled bag, clog in hose, clogged filters, etc.
Remove the vacuum bag, and see if you can visibly see any obstructions, or replace the bag if it's full:
Also inspect the Secondary filter while you have the vacuum bag removed from the machine. If the filter is clogged or dirty, rinse under warm water, and air dry completely before reinstalling it into the vacuum. It's best to wash this filter every 30 days, and replace after 4-5 washings.
Here's a link to the secondary filter on our website if you ever need to purchase one:
Riccar 8800 Series Secondary Filter
Your Riccar 8850 also has a set of exhaust filters that are on the front of the vacuum, near the bottom where the upright body meets the agitator housing. These filters when clogged may also cause the thermal switch to trip. These filters are recommended to be replaced every 6-12 months, and are not recommended to be washed.
Here's a link to 2 sets of the exhaust filters for the Riccar 8850 on our website:
Riccar 8850 Exhaust Final Filters, 2 Sets, 4 Total Filters
It's also possible that you may have clog in the suction port inside of the agitator housing. Remove the bottom plate from the vacuum, and look for the tube that runs on the left hand side from the tray to the rear of the agitator housing. Make sure that this tube is clear from obstructions:
Locate "tripped" fuse – the small white button located on the bottom of the back side of
the main body (roughly one inch to the right of the left wheel)
Using a pencil, paper clip or other pointed object, push the reset button in, you should hear a clicking noise when it resets.
Plug the vacuum cleaner back into the wall, and try turning the vacuum on. It should come right back on. If not, it's best to take your machine into a local Riccar authorized repair facility for further more advanced diagnosing.
Please feel free to ask any follow up questions by adding a comment to this repair, I'm always more then happy to answer any and all follow up questions if you need some clarification. If this was helpful, please rate the repair helpful or leave some feedback for me. Thanks so much,
Chris Jones
Govacuum.com
1helpful
2answers
Riccar model rad.7 upright (radiance). roller brush won't turn and red roller brush indicator is on. roller will turn easily by hand and belt is in place. how do i fix this?
3helpful
Riccar 1500p vacuum won't start
Oct 01, 2008 • Vacuums
Top Riccar Vacuums Experts
ADMIN Andrew
ADMIN Andrew
 Mikey
Mikey
Are you a Riccar Vacuum Expert? Answer questions, earn points and help others
