If your battery does not seem to charge, then you need to carry out some tests on the device, the battery and the charger. First you insert the battery into another cam corder then you try to charge, if it charges, then it means the battery is okay and if it does not charge, then it means the battery is bad and need to be replaced.
Then i will advice you take the charger and try to charge another device to see if it will work, if it works, then it means the charger is alright but if it does not then it means the charger is bad and need to be replaced.
Finally, test the camcorder by plugging a well tested charger and battery into it and trying to charge it, if it does not charge then the problem is from the camcorder.
the camera is provided with a battary charger,take out the battary from the camera put it in the given charger,charge it till u get green light,then try.
It sounds like you may have a faulty battery or charger.
Take the extra battery and whatever you used to charge it (camcorder or battery charger) back to the shop where you bought it and get them to help you figure out what's wrong with their product. Your purchase is still under warranty and you deserve to have a product that works.
The battery chargers that are included with JVC camcorders sold in the U.S. are designed to operate on power from 110 to 240 Volts at 50 or 60 Cycles AC. All that is needed to use the battery charger overseas is a plug adapter to connect into a foreign electrical outlet. These are generally available from a store which carries electrical supplies.
Disconnect DC power cable from AC adapter/charger.
Battery charging will not be possible if the DC power cable is left connected to the AC adapter/charger.
