Frigidaire FEX831CS Top Load Stacked Washer/Dryer Logo
A
Anonymous Posted on May 14, 2014
Washer does not drain, how do i fix it?
Washer will not drain, how do I fix it?
  • Official Brand Answer 2,267 Answers
  • Posted on May 16, 2014
Frigidaire
Level 0:
Answers
2267
Questions
0
Helped
1289818
Points
2557
Good Morning Friend,
I see that your Frigidaire washer, model# FEX831CS, is not draining. Here are a couple of suggestions that you can try.
    1)Check the drain hose for any kinks or clogs. Also, make sure that the drain hose is only 6-8 inches down in the drain pipe. If the drain hose gets backed up with water this error can occur.
    2)Make sure that the actual drain pipe, where the drain hose goes into, is only a maximum height of 8 feet. If it is longer than 8 feet, you will need to cut some of the pipe off.
    3)Make sure that your homes drain pipes are not clogged. If they are, you will need to unclog them. Call a plumber if necessary.
    After checking the above suggestions, reset your washer by either unplugging it or shutting the power off at your homes circuit breaker, for 3-5 minutes. When you restore power, start any cycle on your washer. If you are still having trouble with your washer draining, I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your washer and determine why your appliance will not drain. Hope this is helpful.
    -Best regards-
    WP
2answers
My HAIER HLP23E will not drain. What do I do to fix this?
check drive belt if ok possible cogs under agitator need to be replaced
Kenmore 600 washer with error code DRN. how can I fix this?
The error code DRN means a drain error or your washer is not draining properly.
Most common causes:
  • Clogged Pump or Hose - Clogs are the most common reason that a washer will not drain. Remove the hoses from the pump in order to remove the article of clothing.
  • Faulty Drain Pump - if the washer won't drain water the drain pump might be defective.
The digital screen come up with F21. How do I fix this
F21 means the washing machine has a “water draining issue”, meaning the drain pump itself, or the drain hose is clogged and the washer is having problems draining the water out. In other words, the washer is taking too long to drain the water out of the tub. If you have a front load washer then you need to locate the drain pump which is usually located on the bottom front of the machine. If you have a top load washer then you need to make sure the drain hose is not clogged or pinched. The drain hose is located in the back bottom of the washer
Washer won't spin. Motor goes thru cycle but not spinning
My kenmore washer won't spin - EASY FIX (PART ONE ...
? 5:45
www.youtube.com/watch?v=fRxKs2EEfbU
Feb 1, 2013 - Uploaded by Michael Borders My Kenmore washer's agitator stopped spinning my cloths during the wash. NO BIG DEAL!!!! EASY and ...
How To Fix A Washing Machine That Is Not Spinning or ...
removeandreplace.com/.../washing-machine-or-washer-dryer-is-not-spin...
May 13, 2013 - If your old or new washing machine does not spin we have some diy fix tips ... Fix Washing Machine That Won't Drain - Washer Not Draining ...‎Washer Not Draining Water - ‎Washing Machine Service ... - ‎How To Fix A Washing ...
I have a Kenmore 80 series washer it will not stop filling with water so it wont go into agitate cycle, help
Has your drain for your washer backed up recently? Or is the drain hose from the washer sealed into the drain pipe, meaning that you can't just lift the hose out anymore? There needs to be air around the drain hose or it will cause the washer to allow water to be siphened threw the drain by not closing the filling valve. This can also happen if your drain is backed up. Rooter the drain out and make sure that the drain hose is not sealed up to the drain pipe and see if that fixes your problem.
1helpful
I have A WhirlPool Cabrio.. when i start a load.. it flashes "FL' and beeps excessively.. how can i fix and prevent that?
Fl code indicates an overfill condition. If the washer is empty, then you likely have a problem with the water level pressure switch. If the washer is full of water and will not drain, you likely have a problem with the drain pump or the washer drain line.
If the washer is full of water, make sure that the washer drain is clear and working properly. Check the drain hose for kinks or clogs. If you find no problems with these issues, I recommend that you manually drain the washer using a wet/dry shop vacuum. Check the drain pump and connecting hoses for problems. You may need to replace the drain pump of water will drain out of the washer properly but the pump will not work properly. A clog in the check ball assembly at the bottom of the tub can also prevent the washer from draining properly.
SD code and washer leaking
Sd excessive suds are detected by the washer during the drain or spin phases of the cycle.
The washer will stop and fill with water and then wait for 5 minutes to allow the suds eliminated so that the washer cycle can continue, After the suds dissipate, you can normally drain the washer and spin out the clothes using a RINSE/DRAIN & SPIN cycle. Make sure that you are using HE (High Efficiency) detergent in the appropriate amounts to prevent excessive suds in the washer. This should prevent the washer from going into this routine.
  1. Also check your drain hose for a kink or clog. Check the washer house drain for a clog or restriction. Test the washer to see if it will drain properly.
you can clean with affresh or vingar..let me know..
2answers
Washer does not remove water in final spin
If washer hums when it should spin, and the washer will not drain, you may have 2 issues.
First check that the drain pump, drain hose, and wall drain are free of debris.
The washer may not spin properly if the drain system is not operable.
Once you are sure the washer drain pump, drain lines, wall drain, and drain hose is okay, run a test wash.
If the washer hums but now drains, you fixed one issue.
If the washer still hums, you may have a bad belt, motor coupler, motor itself, etc...
Check parts for wear and replace as necessary.I pulled the drain impeller and found a sock from my little guy stuck in there. Fixed!
check all water outlets to make sure there is nothing blocking the pipes.
you could also go to this link it might help you out..... Washer does not remove water in final spin Google Search
Nextra AA1200
You may have a plugged drain hose. Or possibly your household drains are running slowly. To check the hose, pull the washer out. Turn it off and unplug it. Disconnect the drain hose (the 2" black hose) and see if you can clear it of any clogs. You will need some towels and a container for catching any water.
Leave the washer unplugged for a time (don't get the plug wet) while you check other drains in the house, especially the garbage disposal and toilets.
Plug the washer back in and turn it on and try a cycle.
This is the most common problem for what is happening with your washer. If this does not fix your problem, you may need to call a serviceman, or if you do have slow drains elsewhere, a plumber.
Thank you for uisng fix ya! I would appreciate a rating on this solution.
Kenmore 22062 top load washer
I have the same problem I posted on Bob Villa fix it website If I get an answer I will post it for you. Let me know if you found a fix.
Mllong9163
Top Frigidaire Washing Machines Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
