The simple way is to take a oil pan and lift the tiller with the plug removed and drain it out while holding over the pan. Dispose of oil properly. I have an older model that does not have an oil drain plug.
jj505 has good and bad information. Honda GX25 is a 4 stroke motor, with oil lubricated crankcase. Oil drains out the filler. Oil and gas do not mix on this four stroke. The PDF below is the Honda manual. http://www.smallenginewarehouse.com/images/manuals/GX25-35.pdf
Could a gas/oil mix been used by mistake. When you cleaned carb did you also clean dusty air filter?? Try leaveing off filter first and run. Are you sure you are in "choke position" when engines seems to be running ok,be sure to double check yourself here. If engine runs ecelleant in "choke" sounds like your in "Run" position and positioning is problem not performance.
