Re: Why wont my 1989 cherokee pioneer trans wont shift...
If it is shifting through all the gears manually then you have bad Shift Solenoid. Its pretty simple to change out once you drop the pan you can see it.
If it is shifting through all the gears manually then you have bad Shift Solenoid. Its pretty simple to change out once you drop the pan you can see it.If it is shifting through all the gears manually then you have bad Shift Solenoid. Its pretty simple to change out once you drop the pan you can see it.
You can't post conmments that contain an email address.
how many miles is on the trans, what condition is the fluid in (red, brown, black, burnt smell, metallic shavings, etc). could be shift solenoid for 3&4 or the trans could be going bad! if the fluid smells burnt, looks black, milky, or full or metal then the trans needs to replaced, or completely overhauled, all clutch packs, steels, solenoids, etc, and possibly sunshell, and planetary set!! Good luck hope its a simple solenoid and you can just drop the pan, change it out and be done! some trans have vacuum hoses that run shift points and such, but if 1&2 are fine then im thinking vacuum and TPS is fine! and the TPS will vary voltage as the butterfly opens and closes
check the tps(throttle position sensor)located on the right front of the throttle body.if its out of adjustment or going bad it will mimic a trans problem.
This is a standard shift I am presuming if so this usually indicates a bad synchronizer in the transmission. if it is an automatic trans. it is a speed sensor malfuctioning.
