Computers & Internet Logo
A
Anonymous Posted on May 14, 2014
Verbatim usb driver
Driver assente
Driver VERBATIM 16GB BLACK PINSTRIPE USB
What is your question? Also, do you mean USB "drive" or "driver"? Please supply more detail.
Why doesn't my Verbatim "clip
click start right click on computer select properties then device manager scroll to universal serial bus controllers if you se a yellow question exclamation mark ? ! or a red X you will need to update/reinstall drivers right click select update drivers
once inserted windows 7 should automatically install the drivers
if you computer came with a motherboard disk the drivers could be on it
if you can see your usb drive but its not working
ports(com&lpt)right click update driver
if this fails to fix the problem check the usb leads inside your computer usually
usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts
hope this helps you
1helpful
Im looking for the driver of Verbatim turbo USB 2.0
The drivers for your hard drive can b downloaded from the below link provided.
http://www.verbatim.com.sg/en_SG/products/hard-drives/2-5-hard-drives/page/1
I have verbatim external drive usb 2.0. It used to function properly...but now Windows(xp) doesn't open it at all and properties reflect only 2.95MB space. Its a password protected USB and doesnt even show...
update drivers. other people are having trouble with their verbatim products not registering. If you have any more problems, like finding drivers, e-mail verbatim directly with your problem.
1helpful
2answers
Verbatim drive regularly does not show up as available. I have to unplug it and try to get it to reset. do you know how to fix?
Hello!
I checked the Verbatim website for common Windows/USB drive problems. Since I don't know your exact model the information I'm giving is pretty general, but from the Verbatim website it looked like something that could help.
For one, Verbatim says you don't need drivers for your drive to work, but if you're having issues installing their driver might help. Go to their website (Verbatim.com) and in the top left go to "Support". From there you should be able to enter your model and download drivers. The installation instructions are usually on the same page.
The second potential fix is to increase the USB power to the drive. The Verbatim site says that some of their drives require plugging into 2 USB ports to get enough power to run the drive. If this is the case for your drive, you should've gotten a USB cable that is shaped like a "Y". The two wires at the "top" of the "Y" go into two USB ports on your computer. It also said that if even you didn't get the cable you could still be having power issues. You'll have to go to the Support section of the site and enter your model number to see if this could still be the problem.
Good luck! Remember to rate the responses you get!
Need drivers
Below is the link for the FireLite 160GB portable HD. Drivers are only needed for win98. 2000/xp/vista are plug and play. The manuals are included at this link.
http://www.verbatim.com/support/support.cfm?part_number=firelite+160gb+usb&x=56&y=11
Additionally, there could be a problem with power supply. A switch is on the back...USB or EXT. EXT is for an external supply. (http://www.verbatim.com/products/detail.cfm?product_id=38819801-1143-3415-5FE3682C49A8E37F&cat_id=3883B708-1143-3415-5FB9F3C74069A098) USB is naturally for a USB cable. Clicking might indicate low power when using USB. Switch to the external adapter or get a USB cable with two connectors for the computer (the extral cable draws more power),
good luck.
Need Win98 Driver
Hello Mike
I had the same problem. I found the drive for (Win98SE) I needed on the Verbatim europe site, hope this works for you. Note: make sure you take note of which serial number you have, it is in very small writting on the side of the stick.
http://www.verbatim-europe.co.uk/en_1/article_hi-speed-store-n-go-2-0-drive-_2655.html
Top Ximeta Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Ximeta Computer and Internet Expert? Answer questions, earn points and help others
