SOURCE: About D-Link Modem
I HAVE WIRED D Link ADSL 2 + Router Model GLB 502T BUT I DONT HAVE DRIVERW
SOURCE: GLB-502T Ethernet Port doesn't work, USB does
check whether the driver for LAN is properly installed...if not install it using your driver cd...it might your solution..check it out
SOURCE: problem with my adsl 2+ router glb-502t
check if you have the correct username and password for the ADSL line entered into the router, if its correctly entered then reset the router once it should ideally pich up the ADSL Connection.
Hi Anonymous, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
