Move the intake secondary rocker arm A for the No. 1 cylinder. The secondary rocker arm A should move independently of the secondary rocker arm B.
If the intake secondary rocker arm A moves freely, go to step 5.
If the intake secondary rocker arm A does not move, remove the secondary rocker arms as an assembly, then check that the pistons in the secondary rocker arms move smoothly. If any rocker arm needs replacing, replace the secondary rocker arms as an assembly, then retest.
Repeat step 4 on the remaining intake secondary rocker arms with each piston at TDC. When all the secondary rocker arms pass the test, go to step 6.
Check that the air pressure on the shop air compressor gauge indicates over 400 kPa (4.0 kgf/cm2, 57 psi).
Install a 10 x 1.0 mm adapter to the inspection hole, then connect the air pressure regulator
With the specified air pressure applied, move the intake secondary rocker arm A for the No. 1 cylinder. The secondary rocker arm A and secondary rocker arm B should move together. If the intake secondary rocker arm A does not move, remove the secondary rocker arms as an assembly, and check that the pistons in the secondary rocker arms move smoothly. If any rocker arm needs replacing, replace the secondary rocker arms as an assembly, then retest.
you replaced the solenoid but the code refers to the actuator A bank 1--performance problem or actuator stuck off====causes wiring---rocker arm actuator
have it professionally checked and if faulty replaced , then the code will be cancelled
code p 2646 refers to rocker arm actuator A bank 1---performance problem or actuator stuck off=== causes wiring--- rocker arm actuator
discuss the problem with a service dealer shop or an accredited service shop that has experience on your make of vehicle
with rocker arm problems , to stop rotation it may be bottoming out on a valve spring and not letting the cam shaft turn .
talk with a shop for a proper diagnosis and quote
Common problem will be sludge build up blocking the solenoid. Normally rectified by running a engine flush and then change the oil then have a garage clear the code. If the solenoid is completely blocked, you will have to replace it.
it is the unit attached to the cam shaft that varies the valve timing by moving the cam inside the gear
It is oil pressure operated and electronically controlled
take it to an accredited service center and have the job done professionally
p2647 is rocker arm actuator A- bank 1 stuck on--- to fix it should be the VTEC oil pressure switch.
That switch will be on the cylinder head. Towards the windshield and passenger's side (I think).
Go to www . hondapartsdeals . com {remove the spaces when typing}
Go to parts, enter your car's info. System: Engine Component Vtec Oil control valve. That diagram should help a lot.
