Question about Epson Stylus CX3200 All-In-One InkJet Printer
Why is paper not loading - Epson Stylus CX3200 All-In-One InkJet Printer
  • Epson Master
  • 783 Answers
  • The paper is not curled or creased.
  • The paper is not too old. See the instructions that came with the paper for more information.
  • The number of sheets in the paper stack does not exceed the limit specified for that media.SeeLoading capacities for EPSON special mediafor details.
  • The paper is not loaded above the arrow on the edge guide.
  • Paper is not jammed inside the printer. If it is, remove the jammed paper.
  • The ink cartridges are not empty. Replace cartridges as necessary. SeePrint quality does not improve after head cleaning.
After trying the solutions above, load the paper again. Make sure that you follow any special loading instructions that came with your paper. See also the paper handling section in this guide.
Hope It's resolve all Your Printer Problem,
Or Still having Problem Then follow Us For Epson Printer Support
Posted on May 15, 2014
SOURCE:
Canon load correct paper
•When copying or printing received faxes, check the following:
1. Paper loaded in the machine
2. The paper size specified in <PAPER SIZE> for <CASSETTE> or <MP TRAY>.
•When printing from a computer, check the following:
1. The paper size specified on the printer driver screen
2. Paper loaded in the machine
3. The paper size set in <PAPER SIZE> for <CASSETTE> or <MP TRAY>.
Oct 15, 2013 | Office Equipment & Supplies
Tip
Important!: How To Load Paper In Paper Tray Properly
In the printing process, paper jam more frequently occurs on bad paper handling rather than mechanical failure of the printer. So,to ensure that printing process runs smoothly please pay good attention to the following tips before loading the paper in paper tray of your printer.
Tips:
  • Align the edges of paper neatly before loading. Loading paper without aligning the edges may cause paper jams.
CONTINUE READING...
on Sep 19, 2012 | Canon Office Equipment & Supplies
Red light flashes, screen says "load correct paper: A4." The paper is alreay loaded. I cannot print.
When <LOAD CORRECT PAPER> appears on the display, the size of the paper in the paper cassette or multipurpose tray is different from that of the paper specified in <PAPER SIZE> for <CASSETTE> or <MP TRAY>. You need to load the correct size paper or change the paper size in <PAPER SIZE> for <CASSETTE> or <MP TRAY>.
Check if the size of paper loaded in the paper cassette or multi-purpose tray meets the paper setting specified in the machine.
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Jan 16, 2013 | Canon ImageCLASS D1120 All-In-One Laser...
IMy wife pulled the paper tray completely out of
Loading your paper
Paper loading tips:
● Load paper with the side to be printed facing down.
● You can print photos and documents on a wide variety of paper sizes, from
8 x 13 cm (3 x 5 inch) up to 22 x 61 cm (8.5 x 24 inch). The 10 x 15 cm
(4 x 6 inch) photo paper is available with and without tabs.
● Before loading paper, pull the Main paper tray out (use the Main tray release or
the tray grips) and slide out the paper-width and paper-length guides to make
room for the paper. After loading paper, adjust the guides to fit close to the edges
of the paper without bending the paper. When finished loading paper, push the
Main tray back in all the way.
● Load only one type and size of paper at a time in the same tray.
● After loading paper, extend the Output tray extension to catch your printed pages.
Use the directions in the following table to load the most commonly used paper sizes
into the printer.
Paper type How to load Tray to load
Any supported
photo or plain
paper media
1. Extend the Main tray by
pulling it out with the Main
tray release or the tray
grips.
Load the Main tray
Chapter 2
(continued)
12 HP Photosmart 8200 series
2. Slide the paper-width and
their outermost positions.
3. Load paper with the side
Check that the stack of
paper is no higher than
the top of the paperlength
guide.
4. Adjust the paper-width
inward until they stop at
the edges of the paper.
5. Push in the Main tray all
the way in.
6. Make sure the light on the
Photo tray button is
turned off to enable
printing from the Main tray.
Load paper and adjust guides inward
1 Paper-width guide
2 Paper-length guide
1 Push the Main tray all the way in
Aug 03, 2010 | HP Photosmart 8250 InkJet Printer
Paper not feeding properly
Follow these steps to reload paper:
  1. Remove the paper and make sure it's not curled or wrinkled.
  2. Fan the stack to make sure the sheets are separated.
  3. Open the paper support and pull up the extension.
  4. Extend the output tray.
  5. Flip the feeder guard forward. Squeeze the edge guide and slide it left.
  6. Insert paper, printable side up and short edge first, against the right side and beneath the tab.
    You can load up to 100 sheets of 20 lb plain paper or up to 20 sheets of photo paper.
  7. Slide the edge guide to the edge of the paper, but not too tightly.
    Follow these guidelines when loading paper:
    • Do not load paper above the arrow on the edge guide.
    • If multiple pages feed at once, remove the paper from the sheet feeder, fan the edges to separate the sheets, then reload it.
    • If you're printing on both sides of the paper, try loading fewer sheets.
    • If it's wrinkled when it ejects, the paper may be damp or too thin.
    • Do not load paper with holes punched in it for insertion in a binder.
    • Load the printable side face-up. It's often brighter or whiter than the other side.
    • Load letterhead or preprinted paper top edge first.
    • If you experience paper feeding problems, try loading fewer sheets.
    • If you're using special paper, check the package for special loading instructions.
Follow these steps to reload paper in the Automatic Document Feeder:
  2. Tap the originals on a flat surface to even the edges.
  3. Move the edge guides outward.
  4. Insert the originals face-up. You can load up to 30 letter-size sheets at a time. If you load legal-size sheets, insert only 10 sheets at a time. Make sure the originals are not creased or folded and do not have tape, staples, or other materials that could obstruct the feeder.
  5. Slide the edge guides against the originals.
Feb 27, 2010 | Epson Stylus CX9400 Photo Printer
Epson stylus sx515w paper will not feed properly
pls make sure that you loaded the paper correctly.
Open the paper support and pull up the extensions. Open the output tray and pull out the extensions. Then flip up the paper stopper on the last extension, unless you’re printing on legal-size paper. . Flip the feeder guard up, out of the way, then squeeze the edge guide and slide it left. Insert paper, printable side up, against the right side and beneath the tab. Load paper short edge first, no matter which way your document faces.
Load letterhead or pre-printed paper top edge first.
Do not load paper with holes punched in it.
Do not load transparencies.
Do not load paper above the paper.4.3.4.jpg arrow on the edge guide.
Check the paper package for any additional loading instructions. 5. Slide the edge guide to the edge of the paper, but not too tightly. if you put the paper correctly and still not feeding the paper correctly, that means the rollers of the printer is broken
Feb 12, 2010 | Epson Office Equipment & Supplies
Quits printing and screen says "need service"
A: Power the printer on and press the Load/Eject button to see if
paper will load. If no paper loads, make sure the paper isn't
curled or creased, isn't too old, isn't loaded above the arrow on
the left edge guide, and that the paper isn't jammed in the printer.
If the Paper Out light is on solid, reload the paper, making sure
the paper edge guide is adjusted to fit the paper's width, and then
press the Load/Eject button again to see if the paper will now load.
If the Paper Out light is flashing, turn the printer off, reload
the paper, turn the printer back on, and try pressing Load/Eject
again to see if the printer will now successfully load the paper.
If the printer still will not load paper, power the printer off,
remove the printer cable, and make sure all of the packing materials
are removed. If the problem persists, the printer may need to be
sent in for service and you should contact the EPSON Connection for
assistance.
Jan 13, 2010 | Epson Stylus Photo R300 InkJet Printer
I am getting a supply Rec Paper Cassette alarm error. How do i fix this and have it work again.
Hi ..
This error comes when the paper is not loaded properly in the cassette ... Follow the below instructions to load the cassette and I am sure you will not get the error again.
  1. Grip the cassette handle, and pull it out towards you until the cassette comes to a stop.
  2. Open a package of paper, and remove the paper stack. small_note.gif black_dot.gif If the paper is curled, uncurl it before placing it in the cassette. Failure to do so will cause paper creases and a paper jam. black_dot.gif 17 lb to 20 lb bond (64 to 80 g/m2 ) paper is acceptable. black_dot.gif The cassette holds up to approximately 500 sheets of 20 lb bond (80 g/m2 ) paper.
  3. Load the paper stack beneath the cassette's length guide (1) and width guide's claw (2).
    load_paper_in_cassette.gif small_note.gif black_dot.gif Make sure that the paper stack does not exceed the length and width guides' claws in the cassette. Failure to do so will cause a paper jam. black_dot.gif Do not load extra paper when there is still paper left in the cassette. black_dot.gif Only load one size of paper into the cassette. Do not load different sizes of paper into the cassette at the same time. black_dot.gif Do not load labels or transparencies into the cassette.
  4. Gently insert the cassette as far as it will go.
small_note.gif black_dot.gif The cassette is for plain paper, colored paper or recycled paper only. Loading other paper in the cassette may cause a paper jam. black_dot.gif If copies are curled, or a paper jam occurs, remove the paper stack from the cassette. Turn it over and then place it in the cassette. black_dot.gif If you load paper while making copies, do not load a different paper size.
Closing the cassette When closing the cassette, make sure to push it in completely as far as it will go. If copying is performed when the cassette is not pushed in completely, it will cause a paper jam.
If copy paper is sticking out of the cassette Sometimes, when you pull out the cassette, paper may stick out, as shown in the illustration below. Make sure that the paper is neatly loaded into the cassette, before you push the cassette back into the main unit.
Don't forget to vote if this helps ... Cheers :)
Jul 17, 2009 | Canon imageCLASS D860 All-In-One Laser...
Fax does not know paper is loaded. says load paper
When you load your paper, you must press the Stop/Reset button for it to reconize you have loaded paper.
Nov 17, 2007 | Canon FAXPHONE L80 Laser
Epson Stylus CX3200 All-In-One InkJet Printer Logo
71 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
