Question about Kaz Dehumidifiers
Manual for HDK-030 dehumidifier
How do I change the filter/
Would like information on Hisense dehumidifier serial number: KH5Y9JF 0064?
Google (hisense)(KH5Y9JF 0064)(manual) without parens.
Aug 06, 2018 | Dehumidifiers
Changing the filter on a Frigidaire dehumidifier model no. FFAD5033R10
Hello Paul, thank you for your post!
From my understanding you need help changing the filter on your Frigidaire dehumidifier. I have located a copy of the manual and on page nine it will provide you with proper instructions on how to remove the filter. Best of luck! -Matt
ftp://ftp.electrolux-na.com/ProdInfo_PDF/Edison/66129917125en.pdf
Apr 06, 2016 | Frigidaire Dehumidifiers
How do I change the filter on my dehumidifier lad704tdl
The filter on the Frigidaire LAD704TDL is behind the louvered section of the housing above the water bucket. Remove the water bucket by pressing the sides gently to release the bucket from the dehumidifier. Then pull the bucket towards you and use the handle to move it away. Then reach up and pull the filter down. You can wash the filter or replace it with a new one.
For pictures, see the manual: manuals.frigidaire.com/prodinfo_pdf/Edison/66166042enaen.pdf . The filter maintenance is shown on page 8.
I hope this helps.
Mar 09, 2015 | Dehumidifiers
Shows change filter where is it located?
Hello Ann, this is JK. I understand that you are looking for the location of the filter in a dehumidifier. Generally, you will need to remove the bucket to be able to reach under to remove the filter. Please refer to your owner's manual for more detailed care and cleaning instructions. Hope this helps!
Apr 07, 2014 | Frigidaire Dehumidifiers
How do I change the filter? Frigidaire 70 pint. I bought one with no manual from Lowe's.
Here's a link to your missing Owner's Manual. Look under the section Care & Cleaning on how to remove the filter. This manual will prove invaluable to you. So download & print it for future reference.
http://manuals.frigidaire.com/prodinfo_pdf/Edison/2020266a0180en.pdf
I hope this helped you and thanks for choosing FixYa.
Aug 03, 2011 | Frigidaire FDF70S Dehumidifier
Just wondering if this unit has a filter or filters that need to be changed?? (Frigidaire 70)
Yes, your unit has an air filter, that should be removed and cleaned at least once every two weeks, while in operation, The filter is located behind the louvers on the front of the unit. To access and remove it, remove the water bucket and just inside the bucket holder at the top of the opening, you will see a tab type of handle. This handle is part of the filter frame. Pull that down and out and the filter will come with it. Back flush the filter with clear warm water. Dry it thoroughly, before reinstalling it in the unit. Never operate the dehumidifier without the filter installed.
To assist you further, in case you have misplaced your Owner's Manual, I have included a link to the Manual for your model. You can download and print the manual for future reference.
Hope this helped you. Please let me know. Thanks.
Jun 25, 2011 | Frigidaire FDF70S Dehumidifier
Looking for temperature sensor control for Haier Model DE45-RBG Numbers on part HSU-07 88A MC3A 94V-0
Here is the data sheet for the HSU-07.
http://www.maocc.com/pdf/hdk/e1321aa.pdf
There appears to be 5 different versions of the HSU-07 Let me know which one matches yours and I will try and find a source.
HSU stands for humidity sensing unit.
Keep me posted... on the actual part match per the pdf file.
Kelly
Jun 19, 2011 | Haier 45-Pint Dehumidifier
What does "CF" mean when flashing on Kenmore dehumidifier?
MOST LIKELY CHANGE FILTER. MAKE SURE YOU HAVE INSTALLED THE CORRECT REPLACEMENT PROPERLY. LOOK IN YOUR OWNERS MANUAL FOR RESET INFORMATION.
Mar 02, 2010 | Dehumidifiers
Fan
For model M7DH45B2A Maytag 45 PINT Dehumidifiers
Parts for the unit. www.appliancefactoryparts.com
Part CRCFD5303-010 Fan - $19.99
Part CRCFD3000-030 Motor - $49.99
Parts for others are also available.
Sep 09, 2008 | Maytag M7DH45B2A Dehumidifier
Defective squirrel cage fan
Upon searching further, I found parts for the unit. www.appliancefactoryparts.com
Aug 03, 2008 | Maytag M7DH45B2A Dehumidifier
Dehumidifiers Logo
784 people viewed this question
Top Kaz Dehumidifiers Experts
Bill Long
Gil Shultz
Marvin
Marvin
Are you a Kaz Dehumidifier Expert? Answer questions, earn points and help others
