I am by far not a telco person, but I have been asked to have a Meridian 7316 phone to stop ringing on every incoming call. Obviously its in a hunt group...but which one, and how do I remove it?
Hi Marty,
Don't worry about counting your way through. Just log into the system, and you will see Terminals and Sets. Press next until you see System Programming, then press Show. Next until you see Hunt Groups, and press show. You can pick the hunt group you're changing and delete the extension from there.
If you're not seeing what we tell you you should see, double check the model of your phone.
SOURCE: How do we remove an extension from a hunt group in
Programming is done on 7310, 7324 and 7316 type sets.Enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt, press the show key (top right arrow). The display should now ask for an extension number. Enter extension number you want to change the pool on.
Press the next key 6 times (bottom right arrow) .
The display should say System Prgrming.
Press the show key (top right arrow)
The display should say Hunt groups
The display should say Show Group:
Enter in the group number of the member that you wish to delete.
The display should say Member DNs:
The display should show members for that group.
Scroll to the member you wish to delete.
Press the Remove soft key.
Press the heading key(top Left arrow) till the display says Show Group: again.
Enter in the group number you wish to to change the deleted member to
The display should list the current members of that list
press the Add soft key.
enter in the DN of the member you wish to add
Select Appr & Ring setting for the hunt group member
Press the release key when finished
I don't really know how much more detail I can give. We have 8 incoming lines, and if the incoming call does not know the extension it rings on a 1/2 dozen phones....one of which we do dot want/need to ring.. So I guess what I am looking for is step-by-step instructions to stop a phone from ringing.
I have tried the instructions suggested, but get stalled at : "Press the next key 6 times (bottom right arrow) . The display should say System Prgrming."...because it does not display what is in the instructions ....
