I would try other settings like heat and regular air to see if air is going to this vent. If it does, the flap may be stuck inside that directs the cold air when it is turned on. The vent is moved by a vacuum actuator.
If you have air on one side, that is a good sign. It may be low pressure, but if the air is cold, it is likely the vent stuck shut.
NO HEAT ON FLOOR VENTS
As
per your problem mentioned. There are few solved help links to
troubleshoot these problems. Go through the list and Click the link below:----
http://whatisbyme.blogspot.in/2012/05/2000-toyota-avalon-no-heat-on-passenger.html
http://schematicsdiagram.blogspot.in/2012/02/heater-blows-cold.html
http://repairhelpcenter.blogspot.com/2012/01/hot-air-on-drivers-side-vents-only.html
http://technoanswers.blogspot.in/2012/04/1992-toyota-camry-ac-control-light.html
http://technoanswers.blogspot.in/2012/02/no-heatblower-blows-only-cold.html
http://whoisbyme.blogspot.in/2012/06/2009-mercury-grand-marquis-ac-blows.html
http://schematicsdiagram.blogspot.in/2012/04/ac-not-blowing-through-vents-on-2007.html
http://schematicsdiagram.blogspot.in/2012/04/passenger-side-temperature-is-warm-air.html
These
will help.
Thanks.
As
These will help.
Thanks.
Checked other settings, and it seems the flap is the issue. Is this a tough fix? i can actually hear it trying to open, would it be underneath the floor boards?, it kind of makes a loud clunk as i switch between heat/cool
