The cooling fan is controlled by the EOC and a temperature sensor located at the top of the oven near the control panel. If the temperature is above a 100 degrees there the cooling fan will continue to run. If it does not turn off when the temperature goes below this, there is a problem with either the EOC or temperature sensor. Try turning off the power to your oven for at least an hour to reset the EOC, this may fix the problem.
