Pioneer AVIC-N1 Car DVD Player Logo
Kash III Posted on May 14, 2014
Pyle pld3mu wont read disc
Purchased the radio from a friend. Cd player and everything worked in his car. I installed to my car now the cd is saying no disc after it reads. help!!!!
  • Kash III
    Kash III May 14, 2014
    and its a Pyle PLD3MU radio ... not the one they have stated in the description
Steve Kent
Level 1:
New Friend:
  • Contributor 45 Answers
  • Posted on Jun 28, 2014
Steve Kent
Contributor
Level 1:
New Friend:
Answers
45
Questions
Helped
7581
Points
49
Probably bad disc or possibly you used wrong screws in side of unit that went in to far and are blocking cd to operate properly
5 Related Answers
Anonymous
  • 3130 Answers
  • Posted on Oct 23, 2006
SOURCE: will not read disc & lots of motor noise
Your problem is a common one. The spindle motor is going bad or is bad, and/or you need to clean the laser lens. The only way to fix this would be to take out the unit and hook it up to a test harness. If you do not have a test harness you will need to seek out an authorized repair depot to do this for you. good Luck Ps Please dont forget to rate this thread.
hogan doan
hogan doan
  • 227 Answers
  • Posted on Mar 05, 2008
SOURCE: navigation disc
Do you have an original copy?
hogan doan
hogan doan
  • 227 Answers
  • Posted on Apr 14, 2008
SOURCE: AVIC-N1 "disc read error"
The laser eye need to be re-align or clean up. If you are technical incline, then open it up and clean the laser eye and turn the mounting allen wrench nuts up a bit. If not have someone who knows do it. 'Cause there are alot of things can pop out of place when you opened it. Goodluck.
Anonymous
  • 4 Answers
  • Posted on Jul 17, 2008
SOURCE: AVIC-N1 wont read navigation disc
If your error message is reading "insert appropriate disk" or "inappropriate disk inserted" than I have the solution. Can you just let me know exactly what the message is?
Anonymous
  • Posted on Sep 13, 2008
SOURCE: please insert appropriate Cd
you need http://www.pioneerelectronics.com/PUSA/Support/Navigation/Upgrade+Discs i dont know what one you need but heres the web site. the cost about $150.00 to $250.00 im looking for a place to download it for free limewire.com but hasn't work.
Why wont my Pyle PLD3MU car radio read disc?
Maybe it need a cleaning service. Firsth clean the laser lenss very carefully and after the mechanism complete. If the problem is not solved, possibly the optical pickup laser is damaged and need to be replaced.
Is there a fuse or someting for the CD plyer or radio? My CD player wont work.
there is a fuse in fuse box that powers radio...sounds like a problem with radio itself....if fuse was bad it simply would do nothing"no power at all.
Bluetooth option not available
You may need an optional Bluetooth module installed if the radio does not have a built in Bluetooth transmitter/receiver or the Bluetooth setting needs to be turned on. Make sure that they connected the module when it was installed.
PLD3MU wire harness
check with uneeksupply.com they got a good selection or can get it
2answers
My pyle plcd13mr wont work
garbage unit dont buy no more
CD stuck digital reads no disc
i have the same problem.. just read cd (MUSIC) NOT READING DVD SAYS  ERROR, DISK IS DIRTY
Got a dvd/cd player 7inch screen in car, wont read disc,s tried a cd head cleaner was working fine night b4 just keeps saying ,,,no disc
More than likely it could be a internal problem with the radio. Also make sure the radio is secure properly. A lot of the newer radios r very sensitive n will notice the dumbest lil things anymore.
Getting radio but monitor wont open
hey do u still have the radio i would like to but it form you
Bad performance
You will need to double check your installation my friend, such as make sure all of the power connections are good. If that does not correct the problem, most likely you have a problem in the radio and these days you can get a good Sony or Pioneer in dash with a cd for around a hundred bucks or so. Good Luck
Top Pioneer Car Audio & Video Experts
ZJ Limited
ZJ Limited
xxxxxx xxx
Grand Canyon Tech
Grand Canyon Tech
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
