Removal
1. Turn the steering wheel so that the vehicle's wheels are pointing straight ahead.
2. Turn the
ignition switch to "LOCK".
3. Disconnect the
battery "- " terminal cable, and wait at least 5 minutes.
4. Disconnect the yellow 2-way SRS connector located under the steering column.
Caution: The wheels of the vehicle must be straight ahead and the steering column in the "LOCK" position before disconnecting the steering wheel. Failure to do so will cause the coil assembly to become uncentered which will cause damage to the coil assembly.
5. Remove the engine hood opening lever and steering lower cover.
6. Remove driver knee bolster (reinforcement).
7. Loosen the inflator module fixing bolt from behind the steering wheel assembly using a TORX 0 driver or equivalent until the inflator module
can be released from steering assembly.
8. Disconnect the yellow 2-way SRS connector and horn lead located behind the inflator module.
9. Apply a setting mark (1) across the steering wheel and shaft so parts can be reassembled in their original position.
10. Move the front wheels to the straight ahead position, then use steering wheel remover J-29752 to remove the steering wheel.
Caution: Never apply force to the steering wheel in direction of the shaft by using a hammer or other impact tools in an attempt to remove the steering wheel. The steering shaft is designed as an energy absorbing unit.
11. Remove steering column cover.
12. Disconnect the wiring harness connectors located under the steering column.
13. Remove the
combination switch assembly with SRS coil.
14. Remove snap ring.
15. Remove cushion rubber.
16. Remove shift lock cable (for A/T).
17. Disconnect the
starter switch harness connector located under the steering column then remove
lock cylinder assembly.
