Briggs & Stratton Briggs and Stratton 030451 5000 Watt Portable Gasoline Generator Logo
d
donald mckinney Posted on May 13, 2014
Gasoline generator homelite 4400 watt will not run getting gas spark plug is fireing but will not start..
Hammerite
Level 1:
New Friend:
  • Contributor 26 Answers
  • Posted on Jun 09, 2014
Hammerite
Contributor
Level 1:
New Friend:
Answers
26
Questions
Helped
7220
Points
52
If it has sat for a while, empty the carb. float chamber, flush out with clean fresh petrol. Make sure fresh petrol is in the tank and try again.
4 Related Answers
witserv
William Robinson
  • 144 Answers
  • Posted on May 26, 2010
SOURCE: troy bilt 5550 generator no start please help
fuel, fire, mechanical. Miss one and she won;t run. Are you sure the gas was good? Not some old can laying around that may have turned or become water contaminated? If it was fresh gas, then take off the air cleaner and spray a little wd-40, or ether, or brake cleaner whatever is flammable into the carb throat. Just a 1 second shot is all it should need. Try and start with that. If it starts and then dies quickly, still a fuel problem. maybe a gasket is damaged, or the jet is clogged. When you said you checked for fire, you acutally took the plug out and had it grounded while spinning the motor and saw spark? If you saw a hot spark then you have eliminated fire. Mechanical not likely if it was running well a short time before. If a valve was damaged, it would still run but not too well. My gut feeling is it is related to fuel.
Testimonial: "thanks for the great help i did try fresh fuel and drained the carb bowl but still same prob its a head scratcher i really thank you for your input."
sodeep
Sudeep Chatterjee
  • 3267 Answers
  • Posted on Dec 23, 2010
SOURCE: generator got wet when cover blew off. Started
First of all check if you are getting current to the plug to induce the spark, by trying the following
  1. Connect the spark plug lead to the long terminal of your tester and ground the tester to the engine with the tester's alligator clip
  2. Use the rewind or electric starter to crank the engine, and look for a spark in the tester's window.
  3. If you see a spark jump the gap in the tester, the ignition is functioning. The absence of a visible spark indicates a problem in the ignition system.
  4. your Magnetron Ignition Armature needs to be replaced
Anonymous
  • 185 Answers
  • Posted on Jan 31, 2011
SOURCE: 5500 watt generator won't start.
With starting fluid, it runs, so this means spark and compression and valves closing properly. You mention gas flow, so gasolene is getting to the carb. This would then leave the problem being in the carb if indeed fuel is present at the carb. If you take apart the carb right now, is there fuel in the bowel? Or, remove the bottom screw on the carb, does gas flow out? Does it flow continuously or does it quit? This will indicate if the float valve is indeed opening. The only thing if you have fuel in the bowel and no start, even with the choke closed, is that the main jet must be plugged. Had the unit been sitting for quite a while with gasolene in it? Gas can "varnish" after a few months and this can cause plugging of the jets and other passages. How old is the gas in the unit? Old gas won't burn in the engine and this can also be a problem. Drain the tank, and carb, put some new gas in the unit and try it. You might have to take the carb apart again and use some carb cleaner to blow the **** out of all the carb passages. This should get it going again. Now, most important, when you get it running again, you need to adjust the engine speed so that you do not burn out any electrical equipment. If you have access to a frequency meter, plug it into the 120 volt outlet on the generator and adjust the speed so that the frequency with no load is 62 - 63 hz. This will allow the generator to drop to 60 hz under load. The adjustment is a 5/16 nut, right side of the upper engine, facing you.
eugbug
EugenesDIYDen
  • 479 Answers
  • Posted on May 01, 2011
SOURCE: I have a Briggs and Stratton Elite series5500 watt
Ensure choke is turned on while starting.
Ensure spark lead is fully pushed onto plug.
Remove spark plug and check there is a spark by keeping spark plug against body of engine and cranking engine, if no spark check there are no broken wires in ignition circuit.
Turn off gas tap if present. Remove the float bowl while holding a container under it to collect any gas. Turn on tap and check the fuel flows freely.
Check the air filter is clean. If it has foam elements these can be washed with warm water and detergent, rinsed and then oiled with a teaspoon of oil evenly distributed through the foam.
Generator runs wide open, produces plenty of voltage, but it will not idle down if not drawing any amps
it does not idle when not loaded, generator have to run open to produce power when needed. contact mfg. for more into
I have a Briggs & Stratton model 19E412 type 1131-E1 that will not start with starting fluid. It's getting spark to the plug, changed fuel filter and lines but will not start?
Question edited for clarity.
Question moved to a Briggs Generator category.
Engines only need 3 things to run.
Compression
A spark and the right time
Fuel
When you try and start, remove the plug and see if it is wet with gas? You may have a blocked carb jet.
Check compression.
https://www.google.com/search?q=Briggs+%26+Stratton+model+19E412+type+1131-E1+that+will+not+start
Has gas in bowl and fire but wont start without starting fluid
McCulloch u spray starter fluid Power Generators Questions ...
www.fixya.com > Forum > Tags > u spray starter fluid > Power Generators
McCulloch power generators u spray starter fluid related questions and ... Question about 13HP 338 Cc Portable Generator # FG6000MK ... My 5700 watt 11 HPMcCullough generator wont ... My generator will start if I spray it with either but won'tstay running in less I keep ... The bowl has gas in it and the needle is clean.
This generator McCulloch fg6000mk 11hp has no spark. I've ...
www.fixya.com/.../t7785814-generator_mcculloch_fg6000mk_11hp_no
Jan 13, 2011 - this generator McCulloch fg6000mk 11hp has no spark. I've checked the gas bowl , a small amount of water in the - McCulloch ... water in the bowl not much also sprayed a small amount of starting fluid in .... My 5700 watt 11 HPMcCullough generator wont start. I'm getting good gas to the plug but no spark.
Won't start. I have a never used McCulloch 5700 11HP ...
www.dqrkc.com/support/t1325485-start
Dec 2, 2008 - Question about McCulloch 13HP 338 Cc Portable Generator # ...evaporated. you might tryt a little spray starter fluid in the spark plug ... My generatorwill start if I spray it with either but won't stay running in ... The bowl has gas in it and the needle is clean. ... My 5700 watt 11 HP McCullough generator wont.
1325485 Won't start. I have a never used McCulloch 5700
Starts runs great turn off the it won't start again
Generator runs then shuts off - YouTube
? 8:17
https://www.youtube.com/watch?v=6esHkPyygWw
Sep 6, 2011 - Uploaded by mainblind
How to make Generac generator run bypassing the low oil sensor and ... Great video on low pressure warning switch removal and ...Pulled off the shroud over the sensor. ... It wouldn't start so I replaced the spark plug, gas, and oil - then it did as yours. ... 1200 Watt Generator Won't start - Duration: 14:49.
gasoline engine on portable generator won't start what do I ...
answers.angieslist.com/gasoline-engine-portable-generator-won-start-I-d...
Apr 16, 2014 - gasoline engine on portable generator won't start what do I need to do ... PULL, Take OUT the spark Plug , make certain it is clean and DRY and then start allover again. ... start then when talking pulling rope use electric starter - if won't ...several times till starts, moving choke to OFF or RUN position once it ...
How To Fix A Portable Generator That Won't Start ' My ...
blog.mygenerator.com.au/how-to-fix-a-portable-generator/
Homelite adjust carb
check the gas shut off is on. Check oil, some have a safety shut off on oil .Clean filters and carb
4helpful
2answers
My 5700 watt 11 HP McCullough generator wont start. I'm getting good gas to the plug but no spark.
The spark coil is bad if you have no spark
Small engine repair. Part is expensive.
Have you checked spark for sure?
1) Spray WD-40 directly into carburetor
If machine has spark, it will fire
2) Is exhaust port clogged with carbon and dirt?
3) Get new spark plug
Pull out old spark plug
Put spark wire on plug
Hold spark plug wire with fingers
Put spark plug threads against metal opening where spark plug came out.
Metal to metal
Pull cord or push starter
Look for spark between metal
No spark, then spark coil is bad.
Looking for a users manual for a gp1kw series gasoline generator ,having a hard time geting it to start.Already install new spark plug and gas.it a 1000 watt 2.4 hp 4-store engine,it about 2 .5 years...
There is a problem with fuel flow or carbueration. I would look for plugged fuel filter (sometimes within the gas tank, or a stuck float level, or possibly even plugged jets..
Homelite Lightnin Bug Generator not getting gas
try leaving your choke partially on it may not be getting all the gas it needs,see if it will run then, it wont run full throttle, but this will tell you its not getting enough gas
1helpful
2answers
I have an onan 5500 gas generator that wont start
What is the model? Chances are the carb needs cleaning or replaced.
3answers
Homelite won't start
You may consider installing a new spark plug. 2-cycle engines foul plugs pretty regular. I'm guessing you are using old gasoline??
Top Briggs & Stratton Electrical Supplies Experts
Sean Wright
Sean Wright
ADMIN Andrew
ADMIN Andrew
Are you a Briggs & Stratton Electrical Supply Expert? Answer questions, earn points and help others
