SOURCE: Maytag dishwasher won't start MDB5601AWW
There is a small round item in dishwasher on front bottom, if it is pulled up all the way the dishwasher will not allow water in.
SOURCE: Can you send me directions on how to replace the
Take a screwdriver and remove the inner door panel. The control board has a cover over it with a 1/4" screw holding it in place. Get to the control board and put some eyes on it. Make sure the ribbon cable from the touchpanel is not damaged and well seated into the control board connector. If all looks good, use the techsheet MDBM601AWW to check the touchpanel continuity (tech sheet page 5, and you will need a multimeter to do this). If the panel tests ok you will need a control board 99003431
But it is more likely the touch panel 99003381
Remember to rate this answer, I hope helps. Good luck.
