Question about Kitchen Selectives Food Mixers
Red kitchen selective stand up mixer
Where can I order missing part
SOURCE:
ThaMp3Doctor
  • 8596 Answers
SOURCE: blade won't release from mixer
To Remove Flat Beater, Wire Whip or Dough Hook
1.
Turn speed control to OFF.
2. Unplug stand mixer or disconnect power.
3. Tilt motor head back.
4. Press beater upward as far as possible and turn left.
5. Pull beater from beater shaft.
If the beaters are stored on the shaft of the mixer when not in use, food traces can harden and make mixer attachments difficult to remove. Should this occur, wrap a hot, damp towel around the shaft to heat and expand the area. A small amount of cooking oil sprayed around the shaft may also help. After the beater has been removed, thoroughly clean the beater shaft area with a small brush to remove any food residue.
-Tha Mp3 Doctor
Posted on Dec 30, 2008
  • 6 Answers
SOURCE: Food made with KitchenAid Stand mixer tastes like grease
The k-aid stand mixers do have a tendency to seep oil.
That oil started out as grease but has separated and is probably coming out from around the beater shaft.
Usually just wiping shaft off with a paper towel right before using is sufficient.
Also -the more frequently the mixer is used, the less likely the tendency of the grease to separate.
Posted on Feb 19, 2009
SOURCE: Kitchen Aid Stand Mixer won't release beater
I had this same problem as well.  The beater was stuck like glue to the rotating arm, and it would not budge with any amount of pressure.  I tried the cooking spray and it did nothing.  But today I put a rag in hot/boiling water and then carefully wrapped it around the top of the beater.  I let it sit for 10 minutes. Then I put the rag in hot water again and repeated the process for about another 5 minutes.  When this was done, I covered the beater in a towel (to protect it) and forcefully tapped (ok... I pounded) it with the flat side of my meat tenderizer (it was all I had...you could use a mallet or hammer).  It took a little bit of work because I had to hammer it from the bottom, then the side, then the top to get the little spoke guided through the shaft.  But it did finally come off.  After cleaning with hot water, I put the beater on again and noticed that it was still a little hard to get on/off.  So, I put a little bit of veg. oil on it, and it seems to be better.  Going forward, I will be sure to clean the top of the beater & arm after each use and then coat it with a little oil to keep from sticking.  Best of luck!
Posted on Feb 21, 2009
ricardok45
  • 135 Answers
SOURCE: who repairs kitchen aid stand mixers in the st
Hi. Go to kitchenaid.com, talk with a customer service person and ask them the question. They'll be able to tell you where the nearest "authorized" repair place is. Good luck! ricardok45
Posted on Apr 22, 2009
SOURCE: Kitchen aid stand mixer bought in US, moving to Europe, 220v 50hz
I can not respond to the warranty issues. My kitchen aid mixer is past warranty as well. I live in a country that uses 220V and my kitchen aid mixer is 110V. I have been using my kitchen aid mixer for almost 4 years with no problems at all.
The converter boxes are supposed to blow the fuse on the converter before it reaches your appliance and cause any problems.
If you purchase a 220V kitchen aid (although it would cost more money) it would probably have more power because of the higher voltage.
Hope this helps!
Posted on Jul 30, 2009
I have a kitchen aid stand mixer. model #rkt2651x. it goes very fast when turned on then shuts off. it will go again but turns right off again. age?
That is indicative of worn motors brushes or a speed regulation circuit board problem. It is worth getting it fixed.
I just checked and my diagnosis is sound :>)
I have a kitchen aid stand mixer. model #rkt2651x. it goes - Fixya
www.fixya.com/support/t26909658-kitchen_aid_stand_mixer_model
52 mins ago - i have a kitchen aid stand mixer. model #rkt2651x. it goes very fast when turned on then shuts off. it will go - Food Mixers question. SOLVED: Mixer goes really fast then stops
29 Dec 2007
Questions, Troubleshooting Help & Support Page 3
28 Jul 2006
More results from www.fixya.com
KitchenAid Classic Mixer K45SSWH Troubleshooting - iFixit
https://www.ifixit.com/Wiki/KitchenAid_Classic_Mixer_K45SSWH_Troubleshooting Make sure the KitchenAid Mixer is firmly plugged into a working outlet and the cord is not twisted or split. ... If your mixer still will not turn on, it might be a problem with the motor brushes. If the brushes are worn down ... The most common sign of a failing hall sensor is if your mixer increases to top speed and then shuts down. Missing: rkt2651x
Stand Mixer Shuts Off During Use - KitchenAid Product Help
producthelp.kitchenaid.com > ... > Stand Mixer Assembly and Operation Jul 12, 2017 - Once the steam has dissipated, the unit should turn on again (about 3 minutes). Resolution: If the mixer could have overheated during use let the mixer cool for at least 30 minutes and try to re-start. If you were making mashed potatoes when the mixer shut off it's possible that with excessive steam the unit ... Missing: rkt2651x
images for kitchen aid rkt2651x stand mixer goes very ...
More images for kitchen aid rkt2651x stand mixer goes very fast when turned on then shuts offReport images
FAQs - KitchenAid
https://kitchenaid.com.au/faqs Explore our range of frequently asked questions to get the very most out of your KitchenAid product. Missing: rkt2651x
[PDF]Classic Stand Mixer Speed Control - KitchenAid
https://kitchenaid.com.au/sites/.../stand_mixer_service_manual_speed_control_6-12.p... KitchenAid®. Classic Stand Mixer. Speed Control. Theory of Operation. And. Troubleshooting Guide. (revision date 6/19/2012). D. Pahl ... Mixer Does Not Shut Off page 6. Mixer Does Not Turn On page 7 ... the motor is not running (OFF) the governor ball plate is at its farthest forward position and when the motor is running at ... Missing: rkt2651x
How to Replace the Speed Sensor and Control Board on a KitchenAid ...
? 6:28
https://www.youtube.com/watch?v=41qTqTWQkMI Jan 15, 2013 - Uploaded by eReplacementParts.com
This video tutorial will show you how to replace the speed sensor and control board on a KitchenAid Pro 6 ...Missing: rkt2651x ‎turned kitchenaid rkt2651x stand mixer goes very fast when turned on then shuts...
Mar 10, 2018 | Food Mixers
I have kitchen aid stand mixer and i can't get the beater to attach because the button is stuck??
The button doesn't move. You must push the beater up beyond th notch and turn it while pushing up.
Jan 14, 2013 | KitchenAid KITCHEN AID 5 Quart Artisan...
Missing the bowl raising handle
Check your manual that came with it. There's usually a customer service number. Things like that usually must be ordered dirctly from the manufacturer.
Jan 01, 2013 | Uniworld Commercial Kitchen Mixer 20 Quart
Missing beaters
try this site for your beaters ..
http://www.euro-pro.com/europro/productdetail.aspx?pid=E6DC268A-EF52-4AB3-B332-7A8F5FD0AA85(Euro-Pro+Base+Catalog)
May 09, 2010 | Bravetti 623-715 Stand Mixer
Kitchen Aid Stand Mixer (model 4KSM90OB) won't run.
Sounds like you have solved it already, the phase boards are worth stuff all so buy one and throw it in. It's unlikely to be much else as you have proved the motor runs.
Mar 20, 2017 | KitchenAid KSM103 Professional 5 Series...
No sticker/model number on the bottom of my stand mixer and am missing the paddle attachment and dough hook.
Since you have not given a make...I'll take a stab in the dark and bet you have a kitchen aid...simply because you mentioned the dough hook. Kitchen aid has 14 models of stand mixers. You can match yours up and look at available accessories at www.kitchenaid.com
Sep 01, 2009 | Food Mixers
Leaking oil from the main part. Kitchen aid mixer, only used a few times a year
Leaking of oil in a stand mixer is not necessarily indicative of a large problem.
Kitchenaid stand mixers are overpacked with oil to last the lifetime of the motor. If the motor sits idle for some time (is not used), the oil may begin to drip from the gears and settle. Oil leakage may primarily be seen from around the beater shaft or planetary action.
A stand mixer can lose up to a 1/4 cup of oil before it needs to be serviced.
It is recommended to run the mixer on speed 10 for 2 minutes in order to redistribute oil back into the motor. In order to prevent future occurences, this is recommended to be done every 3 weeks if mixer is not being used.
Jul 09, 2009 | Food Mixers
Can the Kitchen aid accessories fit the Wolfgang puck stand mixer
If you happen to have a friendly toolmaker with a small metal lathe it should not be too difficult to modify KITCHEN AID accessories that fit on to the front powwer outlet. However Puck Stand Mixer accessories are occasionaly offered on the Web. Meat grinders are very common and original Puck pasta maker have also been seen. Get searchin'!
Dec 01, 2008 | Wolfgang Puck Stand Mixer
Replacement parts for Wolfgang Puck stand up mixer
Very close; stand mixer parts (included accessories and manual only) can be accessed from this page:
http://www.wpcookware.com/categories.asp?cat=32
Just select your mixer's part number (located on a sticker inside the base) and click the link for a list of available parts. You will have to create an account to see anything useful, but all they ask for is your name, a password and an email address. When adding items to your shopping cart, be sure to check the 'Select Item' box. The ordering page will ask for the usual info. Prices are reasonable, but beware the shipping cost!
Jun 20, 2008 | Wolfgang Puck Stand Mixer
NO POWER! -- DeLonghi Stand Mixer 7 qt
There should be a overload breaker on the bottom of the motor, tilt it back and look for a little red (probably) button.  other than that, there shouldn't be anything else... if it doesn't  work, it might be defective... Don't give up hope though, those mixers, (used to be Rival, and made by Kenwood in europe) are *SOO* much better than Kitchenaid, it's not even funny *Grin* and good luck.
Oct 03, 2007 | DeLonghi DSM7 Stand Mixer
Food Mixers Logo
27 people viewed this question
Top Kitchen Selectives Food Mixers Experts
Bruce Showalter
eyecam
Marvin
Marvin
Are you a Kitchen Selectives Food Mixer Expert? Answer questions, earn points and help others
