Question about Carrier 38CKC060 Air Conditioner
My ac working is one hour then stop on screen showing e-3 when i restart ac its cooling again
Compressor fails to restart
indicates that the compressor is not communicating with the program board in the inside unit
could be a relay problem
call in the service technicians for a proper diaganosis
Sep 12, 2017 | Honeywell Heating & Cooling
My car AC stopped cooling. it started working again after I refilled the gas but stopped working less than 24 hours after. So I suspect there is a leakage somewhere on the Evaporator
It could be a leakage, but maybe you are low on refrigerant (the liquid that goes into AC's to make them cool).
In both way you should see a mechanic.
Sep 10, 2013 | 2008 Toyota Camry
E1 Error on air conditioner
It's time to call a professional. Call the manufacturer and ask them who they recommend in your area. Note :Some questions can be answered if you put enough information such as brand and model number.
Mar 25, 2017 | Haier HWR08XC7 Air Conditioner
Ac unit keeps reading fl or full. every 2-3 hours. auto clean button drains out about 1/4 a gallon of water and then stops draining. turn back on ac & repeat process every 2-3 hours. I have tried...
After reading over the Owner's Manual for your unit, I wonder if you are operating it in the Cool & Dry Mode. If that's the case, the dehumidifier is in operation, which would account for having to drain the unit every 2 to 3 hours. Ideally, the Cool and Dry Mode should only be operated for about an hour, when the unit is first started . Removing the humidity will allow the AC function to cool more effectively. But, it is not necessary for it to remain in Cool & Dry mode all the time. Because the AC itself unit will remove some humidity too.
Hope this helped you to troubleshoot and solve the issue of having to drain the unit every 2 to 3 hours
Jun 27, 2011 | LG LP1200DXR Portable Air Conditioner
Hi. I recently installed 1.5 T, 3 * Split AC, LG. Whole day the AC works fine and no problem in cooling too. But once in 2 day outdoor unit start making thudding noise continously and does not stop for 4...
Hello
Sounds like the compressor is shuting down on high heat.There could be a couple reasons for this.
1 Check that proper voltage is being supplied to compressor.
2 Freon level may be low.This would be a service call.
3 Bad or intermitent connection at thermostat.
4 Main contacts to compressor sticking,usually burnt or pitted.
Apr 08, 2011 | LG Heating & Cooling
Dell inspiron 1429 would not stop restarting
just read the error on that blue screen...Its a dump error....then tell me....
ashishcgaikwad@hotmail.com or on 9665071117
Aug 27, 2009 | Dell Inspiron 1420 Notebook
VISTA boot stop and shows ACER recovery screen .
Restart PC
Press F8 as it restarts.
Select Safe mode and see if it workes.
Restart PC again.
Select "Last known good configuration"
If this does not work either,
Do a system restore.
Jul 19, 2009 | Acer Aspire 5315 Notebook
AC not stops working when compressor starts.
how many amp service do you have in the house
May 17, 2009 | Heating & Cooling
Carrier 38CKC060 Air Conditioner Logo
35 people viewed this question
Top Carrier Heating & Cooling Experts
Felizardo Erilla
Felizardo Erilla
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
