Accidentally pressed " feature >" key while retrieving voicemail messages. - now when ext. is dialed internally it goes straight to voicemail. How can this be reversed? The person is unable to pick up, but can hear that the call is coming from internal phone and is going straight to voicemail.
SOURCE: nortel neworks voice
If your system is a Nortel Callpilot just log into your mailbox, then press 8, the first option "Record your name in the company directory" is what I think you're looking for.
SOURCE: Unable to transfer calls to a certain internal
The do not disturb might be active on the extension that your trying to transfer to.On the extension that your trying to transfer to, enter feature #85 to cancel out do not disturb.
SOURCE: Want to pick up phone and get an outside line
Yes, put your lines in a line pool, then have your phone automaticly go to Line Pool: <Whatever Pool # you picked, 1 thru 3>
SOURCE: Forwarding outside calls from 1 extension to
You're not forwarding calls, you're TRANSFERRING calls. Try Feature 70.
Carl
