SOURCE: No dial tone and also all the lights are flickering, please Help!
Unplug and and plug back the phones and see what happens.
SOURCE: I would like Line 6 on Norstar System to Ring Different
Normal
0
To Change your Ring Type:
1. Press the Feature button, then * 6
2. Press the number keys 1 – 4 to hear the different ring types
3. Press the OK softkey when you hear your desired ring
SOURCE: No dial tone on receiver only on voice
make shure handset cord is Not pluged in to the Headset jack on the bottom, needs to be in the handset jack (look at the icons)
SOURCE: Nortel M7310 Phone moved to another jack, now no incoming calls
The reason your phones config is not the same as before is because configuration goes by what extension it is. So if you plug your phone in somewhere else, unless you have DN's configured, your extension changes, so say it was extension 21, but now that you moved it, its now 23, those settings remain on extention 21, so if you bought another phone and plugged it into were extention 21 is, it would have the settings that your old phone had before
To access the intercom by just picking up the handset, Press Feature **CONFIG (266344), Select <A. Configuration>, then go to <2. Line Access>, Select that and enter the extension of the phone you want to have access intercom by just picking up the handset. Scroll until you see <Intercom Keys: #,> make sure you have at least one intercom key. Then scroll until you see <Prime Line: #>, Press change until the display reads <Prime Line:I/C> And there you go. Hope i didn't confuse you
SOURCE: Incoming calls sound only on reception desk.
Programming is done on M7310, M7324 and T7316 sets.
To set up ringing you need to enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt, press the show key (top right arrow). The display should now ask for an extension number. Enter extension number you wish to program ringing on. Press the show key (top right arrow)
The display should sat LINE ACCESS
Press the show key (top right arrow) .
The display should say LINE ASSIGNMENT.
The display ask for a line number. press list
The display should say line 001: appear only
press the Chng key till it says appear & ring
press next key (lower right arrow)
The display should say line 002: appear only
repeat the procedure the same as line 001 for the remaining ringing lines
press the release key when finished
Testimonial: "Great! Very specific and easy to follow instructions. Thanks for your fast response. RO"
