HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost,Scanner does not work, Connection problem etc. For find all these software solution just clickhere....
http://www.hp.com/printer/prob676ijt65/solution
ab79
Use the HP Fax Test
The telephone number for this service is
1-888-HPFaxme (1-888-473-2963). The fax service receives faxes and
returns faxes within 5 to 7 minutes to the number contained in the fax
header.
Solution two: Run a fax diagnostic test
Solution three: Check the telephone line and change the HP fax settings
Step one: Test the telephone line
Step two: Change the HP fax settings
If the HP fax product still cannot send or receive a fax, continue to the next solution.
Solution four: Check VoIP digital telephone line
Using
a VoIP telephone service can cause faxing to fail because fax
transmissions are sensitive to the timing of the signals used to
transmit the fax. If using a VoIP digital line is necessary, changing
the Fax Speed Adjustment
setting to
Medium
might improve the ability to send a fax over a VoIP telephone line.
Use these steps to change the fax spcannot send or receive faxes - c01669474.gift to a lower speed.
If you need printed confirmation that your faxes were successfully sent, follow these instructions to enable fax confirmation before sending any faxes. Select either On Fax Send or Send & Receive.
The default fax confirmation setting is Off. This means that the HP All-in-One will not print a confirmation report for each fax sent or received. A confirmation message indicating whether a fax was successfully sent appears briefly on the display after each transaction.
To enable fax confirmation from the control panel
1. Press Setup.
2. Press 2, and then press 3.
This selects Print Report and then selects Fax Confirmation.
3. Press to select one of the following, and then press OK.
Off Does not print a fax confirmation report when you send and
receive faxes successfully. This is the default setting.
On Fax Send Prints a fax confirmation report for every fax you send.
Fax
On Fax Receive Prints a fax confirmation report for every fax you receive.
Send & Receive Prints a fax confirmation report for every fax you send and
receive.
