The other day paper got stuck, I pulled it out and it was working fine but now it is squealing again.
The fuser is the part of the printer that heats the toner to the paper. turn the printer around and open the back cover. You should see a long black bar with green clips on either side to release a paper jam. There may also be rollers in there. Make sure there is no debris in the fuser, and that those clips are in the functioning position (usually down). If the fuser is removable, which I don't think it is in this model, take it out and then reinstall it. Then give it a shot. Usually though high pitched squeal is a toner cartridge thing. If you are using reman cartridges try a new (actual hp) cartridge from office depot or staples.
Hope It's resolve all Your Printer Problem,
Or Still having Problem Then follow Us For
HP Support
SOURCE: Problem with C3100 Printer
Hi Jakebum,
Please click on the web link given below and perform the steps given in the web page to fix the issue.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00786157&cc=us&lc=en&dlc=en&product=1146331
Have a great day!
SOURCE: hp psc 2210 printer jam
your printer need to be opened and check for any lever is struck or dislodge, it will be better if you send it for servicing
SOURCE: Laser jet 1600 printer high pitched squeal
It proberly has dust in the printer near the spool (the picture below)
SOURCE: hp laserjet 1200 series printer
noise is caused by the toner cartridge and paper is not going trough because there is a plastic milar clse to the feed roller that is bent,find it and push it towards the inside of printer (is a black or dark brown plastic mylar)
SOURCE: HP F4280 All in one
The unit may have a paper jam or stuck object inside, if you
have experience a paper jam error before, check the printer for any
object or paper stuck inside, clean roller.
Some error like this can be a problem on the feeder sensor and by this time you may need to replace and repair the unit.
Hope this initial info helps
If you need more help come back.Post /
thumbs / testimonial are
welcome!
