Question about Kitchen Appliances - Others
Foodsaver v3420 Sealer will not seal a bag, You put it in like you're instructed to do and push the seal button and the light comes on but nothing happens, Left it for 10 minutes with the light on and still no seal! You can push the seal button and the pump runs but it will not seal up a bag!
  • 2,509 Answers
It's broken, it should heat up and seal.
Contact the manufacturer here: Sites food saver Site
Posted on May 13, 2014
SOURCE:
Cannot get it to vacuum.
Does it try to vacuum but never flattens the bag? Make sure the bag you are using is completely sealed on the opposite end. Otherwise, the seal on the sealer is probably allowing air to leak into the sealer. If it has a foam sealer, I've found it sometimes helps to run the foam sealer under water, squeeze out the excess water, reinsert the foam sealer (make sure it is seated all the way) and then try again to seal the bag.
Mar 07, 2016 | FoodSaver Food Saver Vacuum Sealer...
Why does the vacuum sealer not seal the bag nor seal?
wow when I ran my food business I seemed the only one that could get this thing to seal right every night , Im gonna say it was because I wasn't in a big hurry , these machines work great but there not fast it takes sometimes 5/10 minutes to get a good seal on them , and you cant overload them either , when it comes to these less is more , makes for a easier time using them
allow the food to stop about two inches from top edge of bag , and wipe any loose food from the sealing surface (inside) as this will affect the seal as well
Jan 19, 2016 | FoodSaver V3420 Smart Seal Vacuum Sealer...
After hands-free red light for sealing turns on, why does it take a long time to start sealing?
Seal-a-Meal FSSMSL0160-000 Vacuum Sealer - Amazon.com
www.amazon.com > ... > Vacuum Sealers
Amazon.com, Inc.Handy indicator lights for "Hands-Free" and "Sealing", plus Open/Cancel button. Keep your busy kitchen running smoothly with help from this easy-to-use Seal-a-Meal ... With its sleek, straightforward design, the compact appliance effectively ... After completing the vacuum sealing cycle, both the motor and the "Sealing" ...Missing: red
Amazon.com: Rival Vacuum Sealer: Kitchen & Dining
Amazon.com, Inc.
Rating: 3.6 - ‎233 reviews
Online Shopping for Kitchen Small Appliances from a great selection of ... Rival FSFGSL0150-015 3 Step Vacuum Sealer w/ Bag Starter Kit ... You push down....wait for Hands-Free light & Sealing light to go on....let go....wait for lights to turn off. ...After a couple of bags were done, I started having an issue in which the unit did ...Missing: red
Amazon.com: FoodSaver FSFRSH0051 FreshSaver ...
Dec 25, 2015 | Kitchen Appliances - Others
V3840 heat strip doesn't get hot
Could be the heating element (wire that gets hot enough to melt plastic) is going bad, how long have you been sealing bags with the unit? If you have used it for some time there is the possibility of build up plastic/residue on the the wire or the surface that actually comes in contact with the bag as I would suspect there is a coated surface the element heats up as opposed to the element / wire coming in contact with the plastic itself!
Nov 19, 2017 | FoodSaver Vacuum Food Sealer - V3840
Foodsaver v3420
Very good vacuum sealer .
Aug 11, 2013 | Kitchen Appliances - Others
Why there say tray full red light
The tape trick didn't work for me. Had to cut the wires. Works for now.
Sep 27, 2012 | FoodSaver Smart Seal Vacuum Sealer V3825
Foodsaver V845 is not sealing? vacuums okay, but won't seal bag.
Does the vacuum seem to run forever and it doesn't seal?
Clean the black foam seals
Replace them if needed. they can be purchased from Tilia
WWW.FOODSAVER.COM
Jan 24, 2011 | Tilia Foodsaver V835 Vacuum Sealer
V3460: no response when pressing seal and inserting bag. What should I do? Thanks
  • Assuming that the unit is plugged in and the plastic bag is in the proper position.........
  • Press firmly and equally on both sides of the cover (where the three raised ridges are on each side). The 2 micro switches that start the vacuum motor are located there and require firm pressure to operate properly.
Jan 20, 2010 | Tilia Foodsaver V835 Vacuum Sealer
How do I turn on my tillia foodsaver my friend lent to me?
Put food in bag. Open lid using latch to right if necessary to release. Put bag in sealer. Close lid. Close latch. Push vaxuum or seal to activate
Sep 28, 2009 | Tilia FoodSaver V2240
Kitchen Appliances - Others Logo
480 people viewed this question
Top Kitchen Appliances - Others Experts
Marvin
Marvin
Irene Tulloch
john h
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
