The steam generator button in a morphy button is stuck in the up position. How do i realease it. Also what type of screws are on the morphy iron.
SOURCE: Can't get my Morphy Richards steam generator off of standby
do this and use the common sense. God bless you
f the iron heats but steams improperly, inspect the soleplate and
clean the vents (see below) and flush sediment out of the steam chamber
(see below).
If the iron produces too much or too little heat, test the electrical cord
. Also test and, if needed, adjust calibration of the thermostat (see the Appliance Controls Fix-It Guide).
If the iron does not spray properly, inspect and clean the nozzle (see below).
If the iron leaks or spits, clean the steam vents, nozzle, and tank.
If the iron sticks to fabric, clean or repair the soleplate. If the
iron stains fabric, clean the soleplate, clean the tank with a
commercial cleaner, and use distilled or filtered water
SOURCE: MORPHY RICHARDS 42256 JET STREAM STEAM GENERATOR IRON does not provide steam
My MORPHY RICHARDS 42256 JET STREAM STEAM GENERATOR IRON has stop producing steam. I have changed the filter and although it heats up, it does not produce any steam.
SOURCE: morphy richards steam generator iron
Try bottled spring water... many times tap water will not steam right...
heatman101
