Camera gives error, The card is locked. Cannot get to menu.
SOURCE: casio camera card error
It could be either a brand that is not supported or there could be something wrong with your card. Casio only recommends Sandisk, Toshiba and Panasonic memory cards. Try one of those brands and make sure you format it with your camera before trying to save pics to it.
SOURCE: Canon Camera - Memory Card error & Card locked error
Try reading the card independent of a camera i.e. on a computer or a photo kiosk to determine if the card is readable damaged
SOURCE: MY MEMORY CARD IS LOCKED!!
Exactly. Sometimes if you use a card reader it will automatically lock the card when you install it. Keep that in mind.
SOURCE: Card Error
firstly don't use the card, don't try and take any further pictures.
If you don't have a card reader, buy one, there under $20 and make the job of downloading so much quicker.
If you get an error with the memory card on your computer there are many programs that can help you recover faulty formatted or corrupt memory cards. Do a search on google and try a few as some are better than others and some work better in certain situations than others.
searches to try
memory card recovery
memory card repair
Corrupted Memory Card
I wish you the very best of luck..
If I can be of further help drop me a line
SOURCE: Card Locked ! Error
Remove SD card, then whilst card is removed, delete all pictures that may still be stored in cameras 'internal' memory (usually just a few) then replace SD card. Should be unlocked now?.
