My JVC GR-DX27EK mini DV has no power. I charged the battery overnight but there is no power there. I tried using just the power adapter and still no power. The red charge/power light comes on but no power in the unit at all. I tried to eject the tape but the door opened and there is no power to the mechanism. Please help.
SOURCE: cannot find driver for jvc GR-D720 Mini Dv digital camera please help!
If it's a JVC GR-D72, then it's MiniDV. Connect the camcorder via firewire to your PC
SOURCE: Eject tape message
We get the eject message and then it will not eject tape. Any suggestions
SOURCE: JVC camera software GR-D70 for windows vista
Like most I have searched the web for drivers, preferably free ones. I emailed JVC Australia who responded with tis solution.
The camera has a connection called DV. The DV connection is used with a cable called Firewire.
Firewire is a driver less cable and will allow you to stream you video footage across from the camera to your PC.
USB is used for data transfer and need drivers, you would use this mainly to transfer still images or data files off a HDD camera.
If you use firewire and the DV connection you will stream the footage across to the PC and the PC will capture the footage as it is playing.
The firewire is about $15 and can be purchase from stores such as **** Smith, Bing Lee, Harvey Normans and Tandy. I would suggest that you take a photo of the connections on your PC as there are two types of DV connections. (4pin - 6pin)
