As you said, it's dragging. First off, check the belt to make sure it is not slipping on the platter or the motor pulley. If it's not, I would have to say that the spindle pulley is freezing up. With the arm on the rest, the platter should be able to be turned by hand and should move freely. If you need more assistance, or would \like to inquire about a repair, please visit me at my website, audioserviceclinic.com. Thank you.
Almost often a wrong set table/arm weight and a dirty needle. . i gues the last. Cleanen record
SOURCE: TECHNICS SL-B280 DUST COVER W/ HINGES
All parts are discontinued for this model. The SL1200MK2 dust cover will not fit this turntable. You can actually have a dust cover made rather simply and cheaply (depending on where you live). Just take the dimensions to a PLEXIGLASS or even a GLASS shop. You can even purchase the Plexiglass yourself, cut it, and glue it together. I would suggest getting it professionally done. You can use any high impact plexiglass. Get something that is resistant to scratches and discoloring.
- DJ PRO LAB
www.DJPROLAB.com
SOURCE: technics 1200sl pitch control
There seems to be 2 issues with this unit. Usually when the platter speeds up very quickly, one of the IC (integrated circuits) are faulty and needs to be replaced. However, I've never seen the 33/45 lights come on in addition. So, perhaps the issue started with faulty 33/45 switches, and it then caused a short to one of the IC's.
This will have to be professionally serviced, as it is not an easy fix. There are various circuits on the main board which control the drive, so it's a matter of diagnosing which is the culprit. The 33/45 switches will also need to be tested/replaced.
- TERMiNAL OPTiC
www.DJPROLAB.com
SOURCE: User manual Technics DZ-1200 turntables & Pioneer DJXM600 mixer
I found your manuals below:
Technics:
http://www.givemefile.net/manuals/musical_instruments/technics/sl-dz1200.html
Pioneer:
http://www.nodevice.com/user_manual/pioneer/dj_mixer/djm-600.html
SOURCE: Distorted sound on Technics SL-1200/1210
You could be getting acoustic feedback from the speakers to the TT's. Lower the volume or somehow isolate them from room sounds and vibrations.
