Miele CVA4070 Coffee Maker Logo
A
Anonymous Posted on May 13, 2014
The grinder is not working
There are beans stuck in the grind chute...which is causing the grinder not to work. Can it be cleaned? Only water is coming through.
  • Big Al Nov 20, 2014
    During thegrinding cycle ... does the grinder make a noise or is it silent ?
Big Al
Level 1:
New Friend:
  • Contributor 38 Answers
  • Posted on Feb 03, 2016
Big Al
Contributor
Level 1:
New Friend:
Answers
38
Questions
0
Helped
73323
Points
57
Likely causes are grinder has burnt out or temperature cut-out for Grinder has blown. Either can be replaced as a spare from Miele.
1 Related Answer
Anonymous
  • 51 Answers
  • Posted on Jun 29, 2011
SOURCE: I owe the miele CVA4075
Make sure the hopper is working correctly to see if there are any blockages, then check under the hopper to the opening where the beans go to the grinder. My guess is that there are a few beans and chipped portions of beans which are clogged under there.
2answers
My Miele coffee maker only dispenses dirty water -- the coffee grinder grinds, but actual coffee never comes out. Help!!
I am guessing the waste basket is empty as well. you may hear the grinder turning but it sounds like no beans are being fed or something is stopping them from falling in the chute - another possibility is the coffee chute (after the grinder) is plugged up as well - sometimes using an oily bean ( dark and shiny) will do this
you can sometimes clear it from the ground coffee chute above the brew unit - but take care not to damage or cause injury to yourself or the unit
Bunn g3 commercial grinder
Humm, G-3 grinders. Okay what common problems I've come across:
* Wrong setting for grind on label. Usually means worn out grinder burrs. But this does not happen often unless you are using it to grind commercial amounts of coffee? It's a retail level grinder meant to be user friendly and simple to use. Say grind a bag of beans once every 10 mins or so even with customers lined up to grind there own. Running a G-3 constantly is usually done by upcoming coffee vendors whom are using it for small flavored bean batches. But expect the burr plates to only last 3 to 6 months. We used to change it every month till the boss bought a bigger pro grinder. (whew!)
* Out of calibration (for grind) This usually happens as soon as it's installed. Either the grinder got banged (Dropped?) around or the lock nut was not tighten down. If caught quickly then it's a simple adjustment. Left unchecked will wear out the burrs or crack the plate.
* Trips out breaker. This is common at retail stores as it's located in a shelf rack that really does not have the required outlets. Many times there is a brewer(s) connected to the same line. It only trips out when one or both brewers are heating and the grinder is running a very fine grind.
* Trips out breaker when grinding espresso or very fine grinds. Worn burrs or slim chance the grinder was miss calibrated (but you would catch this when first installed)
* Shocks the customer. Dry climates or heavy air conditioning will build up static electricity at the chute. There usually a small chain attached to the chute to prevent this. Attach a SHORT metal chain or thin cable to the metal case of the grinder and add a metal clip to attach to the coffee bag. Many use a chain and clip just short enough to keep the bag positioned under the chute. Note many coffee bags come with bag clips. Just make sure the clip and chain can't get stuck in the grinder.
* Not working. This is usually the on/off switch as it gets beat up the most. There is sometimes a safety micro switch under the chute to sense if there is a bag there. I've found may have been defeated.
* No power, check cord, breaker (GFRI) outlet, Plug prongs if broken off or bent.
* power but no motor hum. Tripped thermal breaker (usually a red button on side or back. Some models may have it inside on the motor itself. Call for service to check.
* Turns on but loud hum (may be hot too). Burrs stuck. This could be from adjusting grinder while grinding beans and adjusting to a fine setting. Grinding finer slows down the beans feeding the burrs. Large settings flood the burrs with a lot of beans. Adjustments are usually done when the grinder hopper is completely empty. If loaded and turned down from coarse to fine grind the beans already in the burrs get crushed and stuck between the plates thus locking them in. It may be possible to clear the hopper and open up the grinder to its coarsest setting to jog out the crushed beans. Otherwise call for service to have the burrs cleared manually.
*Finally check with your vendor if your still having problems.
Aloha! ukeboy57
6helpful
3answers
Cuisinart coffee grinder keeps clogging
Unplug first. Unscrew the top. You need a long thin screw driver Phillips head is the best. Pock around the exit and entrance where the coffee beans are ground. Remember, the better the coffee and you will get more clumping of the beans. I works great. It is pain. The Chicago Clout man exits.
1helpful
The bean grinder doesnt grind, only water comes out
If it is working before, probably the coffee chute is clogged up. You can remove the bean hopper and see where the coffee drop into the brew unit.If the chute is still attached just clean the blockage, if it is broken you will have to remove the grinder and replaced it.
1helpful
2answers
I bought new green coffee beans recently, roasted it myself and wanted to use it in the machine but the grinder gets stuck and won't turn. The new beans are harder and smaller than the type I used to have....
This fixes almost all the "beans will not feed or beans will not grind" problems caused by coffee bean dust packed in the burrs. Oily beans cause this problem more fequently.
a. Pour all the beans out the top.
b. Open the settings up all the way and see what else can be poured out. Use your shop vacuum to **** grounds out the spout and backward out the bean bin.
c. Pour in some instant rice and start grinding. Reduce the grind to a small setting like six and then open the settings all the way again. (The grinder will not start at a low setting with the rice in it. If you let it stop, open the settings to about 16 before trying to restart.)
d. Pour out the rice and vacuum out the ground rice.
e. Adjust the grinder to your favorite setting and try a coffee grind. Grind until most of the rice dust is expelled (any remaining trace of rice dust will not affect the flavor of the coffee).
2helpful
2answers
Hello. grinder won't grind
HI
Sounds like you have a blockage in you grind passage. Try removing the brew group. Then inside the machine where the brew unit was setting there is a drop chute where the coffee is dropped into the brew unit. This will be above where the brew unit was. From the left side of the drop chute pull down and back, and it will drop coffee. This will clear an opening that relieves pressure on the passage. There is a passage inside the drop chute area that goes to the grinder. Vacuum it out. It will be on the right side of the drop chute.
Once that is cleared go to the bean hopper. There are 2 knobs in the bean hopper. Turn the large knob to the largest number. You can turn the knob to a larger number any time but it has to be grinding to turn to a smaller number. Now replace everything and make your coffee. Once you have made your coffee you can turn the knob back to a number that was higher than the one you had it on, but only when the grinder is running.
8helpful
2answers
My A-9 Coffee grinder no longer grinds coffee. Have cleaned it and checked it out and nothing. The motor runs but no grounds. Thanks for your help!
2answers
I have a Divina Deluxe and the coffee grinder is moving but it does not appear to be grinding it justs runs until the cycle stops. The machine turns on and gets ready but not grind. I have opened it up and...
Remove brew unit and check the grounds chute from the grinder, if that is clear, then re-insert unit, then when the grinder is grinding adjust to a coarser grind.
Grinder setting stops at drip. Can't turn further to espresso.
Another suggestion is while the grinder is off, turn it up side down and rotate the bean hopper from coarse to fine a couple of times. This will clean out grounds that have gotten into the threads and it will prevent the bean hopper from not turning to a finer grind.
If you start to get a clog in your grinder, open it up to a coarse grind for a few seconds. The coarser grind will clean out the chute and then you can turn it down again while it is still grinding.
Top Miele Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
Aron
David Spradling
David Spradling
Are you a Miele Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
