Orion STV2763 27" TV Logo
A
Anonymous Posted on May 12, 2014
What is the input channel on orion model STV2551? trying to hook up WII and remote does not work.
5 Related Answers
Anonymous
  • 3130 Answers
  • Posted on Mar 22, 2007
SOURCE: can not get tv to go to aux mode to hook up a playstation2
Do you have the original remote control?. Without it you will not be able to switch to video or to the TV mode. If you do have the Original remote hand unit, look for a button call input or video. A universal will not work so please do not waist your hard earnd cash. Good Luck
Anonymous
  • Posted on Nov 30, 2008
SOURCE: No remote for small Orion TV - Input mode?
If u cant get to the aux screen try holding down or pressing one of the channel buttons very quickly.
Good Luck!
Anonymous
  • 27 Answers
  • Posted on Dec 17, 2008
SOURCE: I lost Orion 13" Model TV1318 remote.Need to menu button access
you can purchase a advanced universal remote or you can go through the menu manually on your set
Anonymous
  • 1056 Answers
  • Posted on Jun 28, 2009
SOURCE: Orion model TV1934a - I do not have the original
Try doing a auto channel search while a dvd is on and connected to the TV. An av input is usually reached to the bottom of all the channels. for example pushing the channel below channel two the next one would be AV input.
Anonymous
  • 563 Answers
  • Posted on Jul 11, 2009
SOURCE: I have an Orion TV Mod TV1933b
Unfortunately, with most TVs this function is located only on the remote. If you could do it without the remote there would be a button on the panel of the TV labeled accordingly.
To purchase a replacement remote (a universal remote won't work with that model TV) call Fox International at 800-321-6993. They are the largest Orion parts distributor that I know. Orion doesn't sell parts directly to the public.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please post a comment if you need additional assistance so that I can help you further.
We have tried everything but can not get our DVD player hooked up to our orion tv model stv2750
It could be that you need to change the Audio Video Input to make it work. ON your remote, if there is a button that says... "input" or "AV" or "Aux" or "Source" try changing it. Also, tune your TV to channel 3 or 4 or channel 0. and try each of the inputs... Good luck!
Orion TVD2710. Lost remote, can't change signal input
I would suggest you try to find a universal remote that has an "input" or "source" button and program that one to your tv. By pressing the "source" or "input" button, it will change the input to the tv. I hope this helps! -Der Strom
We lost remote control for our Orion 27" Television. Trying to switch input from Antenna 1 so kids can use XBox
Tries use the front or right side panel manual controls panel.Use the Channels buttons UP/DOWN push the channels UP button couple time.U should get in Video 1 or 2 which ever ur video game console hook in.Or your tv might just have a manual video button,put that u in video 1 or 2.Try website 1-800-remotes Factory original to buy an exact remote ur problem solved.None the solutions,help.
Trying to hook up my wii to an very old model phillips magnavox
I think you have two options here:
1-Maybe your TV aux input is the type where the AUX channel is before channel 2, or after whatever your highest channel number is. If so, you can access that AUX channel by either going channel UP or channel DOWN.
2-If that doesn't work, maybe it's worth the $5 for a cheap universal remote, that you can program, and thereby access the TV INPUT mode.
Hope this helps.
I am trying to hook up Wii but I don't have the remote for the tv. When I bought the tv it was a floor model and it didn't have a remote. I am trying to change the channel for input...channels on tv
Buy a universal remote with an input button if there is no input selection option on the television. Would be helpful if you mentioned the brand and model of your TV
1helpful
2answers
Orion model TV1934a - I do not have the original remote - how can I set it to play a DVD. I have generice remote that does work the TV but the input button on the remote does not work.
3answers
did you figure it out? i am trying to get my orion tv1333 to go into aux mode without a remote. thanks.
No Aux Channel but I have the yellow and White plugs in the front!
Certain Universal remotes have extra menu and input buttons. Take a look around and see what you can find.
1helpful
3answers
Can not get tv to go to aux mode to hook up a playstation2
Top Orion Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you an Orion Televison and Video Expert? Answer questions, earn points and help others
